Cadillac 472/500 measurement help
Discussion in 'The Hokey Ass Message Board' started by mfp-66, Jan 6, 2013.
  1. mfp-66
    mfp-66
    Need help with some measurement off a Cadillac 472/500 engine. I'm using one in a FED and the ch***is builder needs to know some dimensions. Problem is mine is in a mates garage and he's away for a few weeks.
    Anyone able to measure the distance from bottom of the oil pan to the crank center line. Also the length of the block excluding water pump and balancer
    Thanks for you help
  2. Mike Miller
    Mike Miller
  3. metalix_421
    metalix_421
    I can get you the block length, but not the oil pan unless you want a guess. (I built my oil pan)
    I looked at ^^^ the link I didnt know the oil filter was on the driver side I must have an aussie 472
  4. metalix_421
    metalix_421
    27 inches on a bare block
  5. mfp-66
    mfp-66
    Thanks, 1 down 1 to go. I must have an English block I'm sure my filters on the right
  6. metalix_421
    metalix_421
    my filter is on the right as well that is why Im not tfusting that web site for any other mesurments
  7. Mr48chev
    Pretty close to 10 from crank centerline to bottom of stock 76 Commercial pan.
    From what I can figure the block is right at 25 inches. That's measuring out in the snow.
    Here the overall measurements out of How to build a Big inch Cadillac.
