Cadillac Flattys???
Discussion in 'The Hokey Ass Message Board' started by Devils_Instigator, Jan 14, 2009.
  1. Devils_Instigator
    Devils_Instigator
    from Tejas
    Found 2 of these old flatheads. Ones a runner the others a parts motor for $500. I can find anyone who does parts for them?? Any leads??
  2. Crankhole
    Crankhole
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    What kind of parts?
    I'VE GOT CUSTOM CAMS
    FIFTYV8 HAS CUSTOM TIMING COVERS.
    CYCLONEKEVEN HAS CUSTOM ALUMINUM HEADS
    BARRY BURRELL HAS 2X2 INTAKES.
    WHAT KANTER AND OTHER SUPPLIERS LIKE THEM DON'E HAVE, CAN MOSTLY BE AQUIRED HERE ON THE HAMB
  4. Price is real reasonable.
  5. dabirdguy
    dabirdguy
    Very reasonable for a runner....
    Parts motor is a bonus!
  6. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Cyclone loves Caddy Flattys!
  7. Mark Lester
    Mark Lester
    If you can't find what you need on the HAMB, there is a place called EGGY Equiptment in California somewhere that has internal parts for them.
  8. rq375
    rq375
    from Washington
  9. pinstripebob
    pinstripebob
    from Carmel, IN
    Don't use Kanter. They like to send you parts that don't fit, at least suspension-wise. I've got a '42 I'm restoring. Those are heavy engines, 998 pounds wet. Cool though. I've got 2 Strombergs off a Buick I need to get rid of if you want a 2x2 setup.
  10. Abomination
    Abomination
    LOL!
    Was just about to send him to you!
    ~Jason
  11. Devils_Instigator
    Devils_Instigator
    from Tejas
    Well found me a couple of good Lasale trans for these fattys now. Just have to run to SC to go gettem. Looking forward to the trip!!!
  12. HotRodChassis
    HotRodChassis
    Alliance Vendor
    We do intake AND header flanges. Do a "U-FAB" manifold and build your own headers!
  13. plan9
    plan9
    cyclone kev - whats the pricing on your heads? your site doesnt list them.
  14. fiftyv8
    fiftyv8
    from CO & WA
    Nice score especially if they were close to home as they are heavy ****ers and welcome to the Cadillac flathead Club.
    Another source for parts is Maddog in FL, I beleive they aslo have an out let further north up the east coast but I dont recall the State.
    If you ever have any issues with these engines just post it up and we will do our best to give you at the least a good head start on solving it.
    Welcome aboard.
  15. 38FLATTIE
    38FLATTIE
    from Colorado
    By the way, the starter is an easy conversion to 12 volt, by changing the solinoid. I can get you the part number, if you need.
  16. LaSalle Gearbox
    LaSalle Gearbox
    from ohio
    Tyrell Machine in DeLeon TX has engine parts. those motors were used in WWII so there is/was a big parts surplus.
    The lifters are hydraulic, older design, with close tolerances. They need to be not worn out and very clean, install an oil filter if it doesn't have one. I went through a few sets from Tyrell b4 got it right but they stood behind them.
    These motors seem to be sensitive to balance. If I was doing one today, I'd balance everything that spins. The factory made a lot of noise about how smooth they were and they are smooth when right. There is a lot of weight on the crank and I wouldn't fool with it or let somebody else unless they really had their **** together, the factory claims to have balanced it good at time of build.
    the Pistons at least on the earlier ones, have a slot under the rings that if any longer would make the piston automatically fall apart. So they're kind of weak there, maybe the aftermarket pistons are ok.
    the heads had different styles of ribs etc cast into the tops of them every year so you can sort of tell what you got.
    get a cadillac shop manual for dimensions, tolerances, and how to do stuff on these engines. also a factory parts book is handy, both available from the usual suspects.
  17. Abomination
    Abomination
    FYI:
    Terrill Machine Inc, 1000 County Rd 454, DeLeon, TX 76444, 254-893-2610
    There's also a list here of Cadillac parts places that had no web pages at the time here:
    http://www.cyclepsycho.com/caddy/parts2.html
    ~Jason
  18. superchiicken
    superchiicken
    coopersvintage.com in burbank ,ca 818-567-4140
  19. fiftyv8
    fiftyv8
    from CO & WA
    Dont forget flatcaddy.com following on for 38 Flattie.
