Technical Cadillac lasalle 3 speed steel syncronizer?
Discussion in 'Traditional Hot Rods' started by 30yr32, Aug 17, 2020.
  1. 30yr32
    30yr32
    from Michigan
    Am about to pull the 41 side shift trans out of my roadster for a rebuild. Bought a syncronizer ***embly off eBay and the br*** rings are steel on this one. Could it be a later part or aftermarket race part? Anyone had experience with steel syncronizer rings? They’d do look identical to the original br*** rings. Sure would appreciate any experienced input as I have to pull the engine to get the trans out.
  2. Beanscoot
    Beanscoot
    Are you absolutely sure they're steel and not just plated so they are silvery coloured?
    Check with a magnet.
  3. Paul
    Paul
    Editor
    Are you sure they are not aluminum?
    Bronze left, aluminum right
    Beanscoot likes this.
  4. vtwhead
    vtwhead
    put up a pic of it so we can visualize
  5. 30yr32
    30yr32
    from Michigan
    Paul nailed it. Aluminum. ***embly must have been recently bead blasted as they had the same color and texture as the steel components. Checked them with a magnet and file. Sorry I can’t figure out how to post photo. Are the aluminum some aftermarket replacement? This site is amazing with 70-80 year old information still out there. Thanks everyone
  6. Paul
    Paul
    Editor
    Don't quote me but I think bronze was early and aluminum was later.
    I have found them both in various years of Cadillac but only aluminum in the '50 Olds I've opened up
