Technical Cadillac/manual trans
Discussion in 'The Hokey Ass Message Board' started by LarsL, Jan 30, 2026.
  1. LarsL
    LarsL
    from Norway
    Ok friends!
    Im down the rabbit hole thats Cadillac engines.
    I have several on the list but i have a hard time figure out witch engine type is the more easy one to find a trans adapter to.
    Has someone made a 390 to early Ford 3speed adapter?
    I know of the flat plate for the 49-53 331 engines but in case i go for the 390, Whats the options?
  2. 562roadster
    562roadster
    The easiest one to find is the flat plate adapter for 49-54 331 engines. 55-62 adapters are pricey. From memory, offenhauser, cragar and speed gems made them.
    dana barlow likes this.
  3. stuart in mn
    stuart in mn
  4. LarsL
    LarsL
    from Norway
  5. flamedabone
    flamedabone
    Here is the Speed Gems live and in person. Not sure if you could conjure a Ford 3 speed pattern or not. I know you are pretty hard core on tradition, but it sure is nice to have a 5 speed, which will bolt right up with the Speed Gems.
    -Abone.
    dana barlow, RMR&C and kadillackid like this.
  6. 51 mercules
    51 mercules
  7. 51 mercules
    51 mercules
    RMR&C, kadillackid and anthony myrick like this.
  8. Attached Files:
  9. 51 mercules
    51 mercules
    Did they use the same part number? I know they did on some of their other adapters.
  10. 562roadster
    562roadster
    yep same part number, 303
    51 mercules likes this.
  11. Yeah, as 562roadster said , same number
  12. Mr48chev
    I'm going with the theory that the general concept from the adapter manufactures was in is that big bell Ford transmission just cannot handle the Torque of the big Cad. Not traditional but I have an AX15 from behind a V8 in a two wheel drive late 90's Dodge Dakota. Sold the Bellhousing on Ebay for almost enough to pay for the Novak AX15 to Chevy bellhousing adapter. When I adapt a stick off a SM420 that laid out in the sand for a lot of years to the stub stick on the AX15 and put a nice boot on it it will look like I am running an SM 420 and I will probably get commments on it and grin and go with it.
    I understand tradition and my boat tail roadster will be 99.9 traditon right down to the six volt generator. It can ride on the trailer behind the 48 if it has to go someplace more than 100 miles from the house.
  13. 51 mercules
    51 mercules
    Thanks!
  14. ckh
    ckh
    As 562roadster said adaptors for 55-62 engines are hard to find and expensive. So are multi-carb
    intake manifolds. I paid $500 for my Cragar 303 adaptor and twice that for an Edelbrock 3 two
    manifold for my 55 331 and was glad to get them. I don't care for the 49-54 engines because of the
    bellhousing being cast into the block. Don't be discouraged, keep looking for a Cragar or Offy 303
    adaptor on the HAMB, ebay, instagram or any other website you can think of. I had a parts wanted
    ad for the Edelbrock 3 two manifold on the HAMB for a year with only 1 reply, and it was for a 4 two
    manifold. I called a friend in Indiana and asked him to help me find one. He called my back 20 minutes
    later and had found the one I now own on instagram! Cadillac's are a challange. They aren't small
    block Chevys. You have to really WANT one. Best of luck with your projet and keep us posted.
    CKH
    warbird1 likes this.
  15. LarsL
    LarsL
    from Norway
    Thanks for all the help!
    I was thinkin using torque tube setup/3speed. Flatheads are expensive here in my neck of the woods.So thats why im thinkin overhead valve. And since i like it traditional/old i was thinkin Cadillac. And i believe a 3speed/v8 rear will keep up with the cad, as long as you not drop the clutch like a racer. But hey, ideas and options Welcome!
    Barrelnose pickup likes this.
  16. ckh
    ckh
    I like the way you think. You can spend big bucks on a flathead just to make 170 HP. Not me! A stock
    Olds or Cadillac has much more power. An early Ford trans and torque tube rear will live as long as
    you treat it with respect. I think in the long run you may find the Olds less expensive than the
    Cadillac. Thats for you to decide. I can tell you are a hard core traditional hot rod guy like a lot of
    us on the HAMB. Living in Norway makes it even harder. My hats off to you Lars. Hope things work
    out for you.
    CKH
