Cadillac Porn!! A little something I'm working on!
Discussion in 'The Hokey Ass Message Board' started by 6deucecaddy, Jun 15, 2009.
  1. M.Edell
    M.Edell
  2. 6deucecaddy
    6deucecaddy
  3. 6deucecaddy
    6deucecaddy
    By the way i tried hammering the shaft down to hopefully bring down the rotor clearence and nothing.
  4. M.Edell
    M.Edell
    I wonder if its defective.You said its an NOS unit? I have come learn that alot of "NOS" Stuff is "NOS" for a reason..alot of times they were defective and just got thrown back into inventory or unmarked as being defective only to end up in the hands of someone 40-50 years later..Believe me, that happens too..
  5. Evel
    Evel
    1. 60s Show Rods
    nope stock...I do know that Robert Lomas with the black 34 converted his Mallory to HEI
    and he said that he dropped it right in and it ran like champ... I don't know if hes a HAMBEr..
  6. Evel
    Evel
    1. 60s Show Rods
  7. I believe you have the wrong cap, it should be a 24004, not just 4004. The 24004 has "flat" contacts and not "stepped" as in the 4004. I have added pics! I use the spring loaded 24215B rotors with this cap, this is on my 390 Cadillac Magspark, hope this helps :) Love the engine!!
  8. 6deucecaddy
    6deucecaddy
    I looked on eBay for the rotor model number 24215C and it seems like it sits lower on the shaft. Maybe the 24215C rotor goes with the 4004 cap?
  9. Exactly what I am thinking as well, this pic is originally off this forum :)
  10. 6deucecaddy
    6deucecaddy
    It also looks like the metal piece on the rotor is shorter on the 24215C compared to the 24215B. Also I noticed that the 24215B rotor has a spring on it unlike the 24215C. That's weird cause my 4004 cap has a carbon center and is also spring loaded. I've never seen both the rotor and the cap both spring loaded. So i'm sure I have a wrong rotor or cap. I'm going to buy the rotor on eBay and I'll see what happens. Thanks for the info.
  11. Cool, Let us know how it turns out when you get the other rotor, it is always good to know what our options are on replacement parts! :cool:
  12. eightbanger
    eightbanger
    Sweet engine!...nice,...real nice.
  13. greasy50chevy
    greasy50chevy
  14. M.Edell
    M.Edell
    Ah.. just send me the engine and put a Chevy in it...LOL! Just Kiddin
  15. 6deucecaddy
    6deucecaddy
    Hahaha! Too much time, money, and being bitched at by the girlfriend to just put a Chevy. I think I have it figured out though. I think I have the wrong rotor. The one I have is too long. The rotor I have is for the older brown cap 24004 and not the black newer cap 4004. Thanks for all the help.
  16. jfrolka
    jfrolka
    Cut it down to clear the cap, i've seen better exhaust readings with the rotor matched to the cap.
    The pertronix is a really good deal. I just dropped it in on my 429 and it cleaned up the idle tremendously.
    What you got for a cam?
  17. 6deucecaddy
    6deucecaddy
    Im actually thinking about installing the pertronix setup since I've only heard good things about it. I can't just grind the rotor down since both the cap and rotor are spring loaded. Only one or the other should be spring loaded. I have the wrong rotor.
    I have an ISKY cam in it but I don't remember exactly what kind of grind it has.
  18. 6deucecaddy
    6deucecaddy
    Does anyone know the model number of pertronix I would use with my Mallory ZCM distributor 303A?
  19. jfrolka
    jfrolka
    I believe there is only 1 pertronix kit. Whats so different about the mallory to the factory dist?
  20. 6deucecaddy
    6deucecaddy
    The Mallory is a dual points distributor.
  21. Almost cartainly a mis-match of cap and rotor arm The picture shown of the three arms the one in mine is nearest to the right hand side one. Looks like the long arm rotor matches to the short button cap. The short arm rotor matches the cap with the 'half cut away' brass terminals.
    The rotor can also sit high mine did just carving a little of the underside bakelite out before I realised , don't hammer it though just a litlt tweaking this way and that and she should drop a little.
    Keep going with it they are real nice once set up.
    Have you noticed that both the strong and light bob weight springs can be tensioned individually to allow a 100 percent mapping of the advance curve. Leave alone until you have got it running though.
    good luck and have fun
  22. O.K.E.
    O.K.E.
    from norway
    I know it’s been 11 years since the last update here. But I’m pretty sure that this is the engine I started for the first time yesterday, after the rebuild in 2009. It’s now installed in my 1935 Ford.
    C2C280E7-75CE-4859-A01B-20DE418EE549.jpeg BED23FFB-EBC3-48DC-B485-FFE64A82168A.jpeg 9EEFE851-A78C-45B2-A271-EFDC5B13EA57.jpeg
  23. Good looking motor, just been through the thread.
    What’s the generator/alternator?
    Fits in that position well!
    Thanks
  24. e1956v
    e1956v
    Alliance Vendor
    How is that lawn tractor/industrial engine alternator working out for you? They are pretty low amp and I never thought of using one on a hot rod build, it looks really clean. Where are you going to mount the regulator/rectifier combo at?
    Sent from my iPhone
    www.speedoservice.com
    Should I rush your rush job or the rush job I was rushing when you rushed in?
  25. e1956v
    e1956v
    Alliance Vendor
    It’s a unit use on industrial engines like Kohler engines on John Deere tractors. They are permanent magnet and put out AC voltage that is then rectified to DC by an external regulator rectifier. They are low amp but put out as soon as they start turning.
    Sent from my iPhone
  26. O.K.E.
    O.K.E.
    from norway
    Haven’t driven it yet. I’m upgrading the brakes and putting in a new rear end also, so want know for sure before next summer how well the alternator will work. But I couldn’t figure out a better way to have a charging system and still run hood sides. The regulator is mounted on the frame rail. The alternator out put is 20amps if my memory is right, and that should be enough for normal driving with lights on. With a lot of short trips or sitting in traffic with fan and lights on it could be a problem, but I don’t mind having to charge the battery when parked at home. So I think it will be fine.
    loudbang and e1956v like this.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is a pretty engine install. Nicely done.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    Why not run a mechanical fan? My 40 running a 331 caddy and a 4 blade fan and no shroud runs at 170 degrees all day long
  29. O.K.E.
    O.K.E.
    from norway
    Wow that looks great! I was also thinking about mounting a generator where you did, but then there is a fuel pump issue.
    There is not enough room for a mechanical fan. I have less than 1/2" from the water pump pulley bolts to the radiator and it’s leaning backwards so no room. I could have moved the engine back more, but then I would have run into a hole lot of other problems. Moving firewall, steering column, pedal assembly, cut a lot out of the x member and loose leg room..
