Hot Rods Cal Custom valve cover question
Discussion in 'The Hokey Ass Message Board' started by loveoftiki, Jun 28, 2014.
  1. loveoftiki
    loveoftiki
    from Livonia,Mi
    I wanna put em on my 352. Went to try to find a grommet to fill the filler type holes in em for my Pcv valve and breather. The only grommet I could find was the mr gasket type at oreilys but they don't fill in the ears of the hole. I was thinking of using some permatex to fill in the 2 voids in each grommet....unless someone on here has a better solution
  2. fordor41
    fordor41
    If they have "ears" there are for a twist on cap not push on
  3. roundvalley
    roundvalley
    I used a Mr. Gasket #97003906 on my Cal Custom and they worked well. Not sure what you mean about the ears but it sounds like a twist cap.
  4. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yep twist cap. I was just gonna run some permatex around the 2 open areas around the grommet for my breather and Pcv valve, but wanted to see what others have done.
  5. kadillackid
    kadillackid
  6. Muttley
    Muttley
  7. loveoftiki
    loveoftiki
    from Livonia,Mi
    Guys thank you! My old FE is gonna look a little nicer now...ha ha 85,000 miles oil and all
  8. HOTRODPRIMER
    HOTRODPRIMER
    I bought the one Muttley is referring to above from Dennis Carpenter for my valve covers. HRP
  9. loveoftiki
    loveoftiki
    from Livonia,Mi
    yep placed my order....at 5 bucks they are making good money I'm sure but at $22.00 they better at least buy me dinner and kiss my cheek
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    Ok held off on the order...figured I'd try npd...drove over on my lunch hour. Part # 6A892-3 = $2.95 a piece...now I really wanna be the guy selling em for $22.00!
  11. 40fordtudor
    40fordtudor
    You can be sure the $22.00 guy don't have a lunch hour-----
  12. loveoftiki
    loveoftiki
    from Livonia,Mi
    Hell at 22.00 for a piece of rubber about the size of a half dollar I bet he has more than a lunch hour
  13. 1971BB427
    1971BB427
    from Oregon
    I went to the place I hate; Autozone. They have a corner in the store with PCV valves, fuel filters, grommets, etc. I found grommets with a large enough lip on the top to completely cover the notches for a twist in breather. They were a couple bucks each. I still lifted the lip and squeezed some black RTV under the notch after I had the grommet in place. Worked great, and no seepage. Also got the correct grommet for my PCV valve too!
