Hot Rods Cal Neva 34 3 window coupe. What brand/ size tires?
Discussion in 'The Hokey Ass Message Board' started by domingo, Sep 22, 2017.
  1. domingo
    domingo
    from Lima, Peru
    Hello.
    I was wondering what brand/size tires is the Cal Neva 34 coupe wearing???
    Any way to find out???
    Sent from my SM-G930F using The H.A.M.B. mobile app
  2. wheeltramp brian
    wheeltramp brian
    i believe it has 700-18 on rear and 500or 550-16 on front.sae it a couple years ago.foggy memory
  3. domingo
    domingo
    from Lima, Peru
    18 incer out back??? Really...im trying to figure out the stance on my car and which wheels and tires to get....
    I mocked and supported the frame (no tires on it) to the height where I want it to and then took a 33x12.5 r 17 tire off my truck (i measured it and in actually measures only 31.5" tall) and then the front had the stock 34 16" wire wheel with a 27" tall tire.
    I figure I want a 7" or 8" tire tread out back amd about 5" tire tread up front. Front tire is an old Goodyear and it reads on the side wall 6.5 but its actually just 5" wire on the tread when i messure it. It throws me out when the side wall specs are not the same as the actual gire dimensions. So if I Could find out what are the exact tires the Cal Neva 34 is wearing it would be awesome. Thats kinda the same stance Im going for.
    Im located in Lima, Peru. So ordering the wrong wheels anf tires would be an expensive mistake.[​IMG][​IMG]
