Calculating Horsepower
Discussion in 'HA/GR' started by 348chevy, Aug 3, 2008.
  1. 348chevy
    348chevy
    I used to have a site on my computor that would let you calculate horsepower by the weight and speed at the end of the quarter mile. If you know the weight of the car plus you and the speed of the car at the end of the quarter mile it will tell you what your HP is. I remember using it with my 58 and it was pretty accurate. Does any one know the formula or a site that gives that info? This would be a good thing for those who don't have a dyno and would open some eyes on what a penalty weight is.:)Roy
  2. CrkInsp
    CrkInsp
    from B.A. OK
  3. 348chevy
    348chevy
    Well I ran the numbers on my car and it says I was making 205 HP to achieve 113.58. Not much by todays standards but it certainly shows that a little HP equates into a bunch of fun.:DRoy
  4. ThingyM
    ThingyM
    Hey that is pretty cool.. According to that. I aught to be able to beat that little Ol' Lady in the wheelchair...Watch out Tom.. I'll be after ya.....he he he...
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sounds good. Pounds per horsepower is the name of the game.......
    I may not have the horsepower, but I have the hole saws and I know how to use them.:D
  6. Moroso sold a slide rule for that years ago. probably still does. I have two here for some reason. Comp cams had a program on thier large floppy disc deal but i dont know about now. I use Mr Gaskets Desk top dyno and the mating drag program. Usually can come within 2 /10ths on paper to track. A couple of times right on. You have to be honest though. If you lie to it it will lie back to you. Doesnt do the same as the others (weight , 1/4 speeed + HP)but it is a very useful tool.
    Don
  7. iagsxr
    iagsxr
    Try these;
    HP= weight/(et/5.825)cubed
    HP= (mph/234)cubed x weight
    don't know how to type the little upper case 3(cubed)
    I'm curious how close these equations come out to what you're using. The mph equation, I think, will give a more accurate hp number as the et equation ***umes optimal gear ratio and traction.
