Bought a 49 chevrolet styleline deluxe couple years ago no ***le or paperwork but because I'm an idiot thought the body number tag was my serial number and I could have it verification now I've been working on it for a year wanted to get paperwork to drive it to its first show in may now I'm stuck after research found that the Vin is on the jam a pillar and after looking it has been removed and is no where else on the car or is it ? Should I pull parts of and sell it as a donor or is there a way around this
Call a QUALIFIED ***le service, or a vin verifier. California DMV is not too hard to deal with, if you do your homework first. sounds like a candidate for an ***igned vin number, but you must find the frame number before you begin the process.
I have read that frame wasn't stamped on the 49 not till 55 or does someone know where to find serial number on frame ?
If you are a Member,triple A can help you too!DMV has changed here in Commiefornia,should be of help too! ROY.
if you go to DMV be sure to get an appointment. do not go to AAA for something like this. if someone does not chime in with personal experience with this then contact Donna Leek / professional registration services in Sacramento area 530-320-5708 (pro.reg.service@gmail.com)
