Hot Rods Caliper sticking
Discussion in 'The Hokey Ass Message Board' started by okiewelder, Nov 14, 2016.
  1. okiewelder
    okiewelder
    from central Ok
    Yes sir you are correct. The only question for the MC was power or non power. I can not imagine non power for a car the size of the vette.
  2. V8 Bob
    V8 Bob
    I've driven a friend's '65 396 Vette with manual discs and the braking is very comfortable. :cool:
  3. V8 Bob
    V8 Bob
    Tapered wheel bearings should always be adjusted with some pre-load, never loose. Reduced bearing life and/or failure will result.
    Those Bendix designed caliper's pistons retract just fine through normal rotor flex if in good working condition and lubed/***embled properly.
  4. okiewelder
    okiewelder
    from central Ok
    My kit came with calipers off a 76 cutless l think? I replaced one but can not remimber. Single piston simple design
