Hot Rods Calling 235 Chevy experts; What is this?
Discussion in 'The Hokey Ass Message Board' started by panheadguy, Aug 11, 2017.
  1. panheadguy
    panheadguy
    from S.E. WI
    Found in a bag of bolts marked "Timing Cover" Stamped metal, .038 thick, looks like heat treated or spring steel. The "U" part looks like it would straddle a 3/8" bolt? Any thoughts?
  2. squirrel
    don't recognize it.
  3. 1961 Poncho
    1961 Poncho
    from Las Vegas
    The photo isn't the greatest but methinks it's a retainer clip.
    I will check my manual for you after breakfast.
  4. 302GMC
    302GMC
    from Idaho
    Looks like a bent clutch fork retaining clip. Didn't come from any Chev or GMC timing cover ...
  5. squirrel
    not a 235 clutch fork retaining clip, either.
  6. panheadguy
    panheadguy
    from S.E. WI
    Thanks for all the input. You never know what you might get with a basket motor. If you guys don't know what it is nobody will. Def. not a clutch fork part...
  7. LAROKE
    LAROKE
    The fun thing about the stovebolt timing cover is that the two bottom capscrews are accessed from inside the crankcase (the pan has to be removed to get to them). That may very well be some type of locking clip.
  8. squirrel
    the original locking clip is a flat piece of metal with two holes in it, it looks nothing like the mystery part.
  9. LAROKE
    LAROKE
    Thanx Jim. I've seen mine after cursing my pan off. I thought that might be a trailer park replacement for a lost one but it's a stretch since I can't see how it would work in that capacity.
  10. squirrel
    I have no trouble believing that it's a stray part from something else. Happens all the time.
    6inarow likes this.
  11. panheadguy
    panheadguy
    from S.E. WI
    It's not that clip. I have the one with two holes for the timing cover. But thanks for thinking about it.
  12. 56sedandelivery
    56sedandelivery
    I think that's the next, "put a caption to this", from Labowski.
    I am Butch/56sedandelivery.
  13. Com'on...its for setting dual points at the same time.....
  14. BJR
    BJR
    Come on..... it's a "C" clip with a handle.
  15. blackrat40
    blackrat40
    Con rod nut lock from a Henway?
  16. panheadguy
    panheadguy
    from S.E. WI
    You're on to something now......
  17. I never saw one inside a Selectric Typewriter, Harley Panhead, 650 Triumph, 216 or 235 Either
