Customs CALLING ALL MACHINISTS (GM Steering wheel spline info?)
Discussion in 'The Hokey Ass Message Board' started by Sir X Loin, Oct 10, 2018.
  1. Sir X Loin
    Sir X Loin
    Ive done the search function on here and every other site to no avail. I am looking to get the detailed information on Some GM Steering wheel splines. in particular a 51 Chevy and a 55 Buick spline. My plan is to 3d print a splined bushing to adapt the Buick wheel to my 51 Chevy. Other than, "The Buick is larger" I cant seem to find any details.
    Thanks!
  2. 302GMC
    302GMC
    from Idaho
    Nothing to it … Cad & Buick use the large size, the other GM products use the small.
  3. Sir X Loin
    Sir X Loin
    ID-OD, spline taper, angle... even some more detail than small and large would be nice.
  4. squirrel
    3d print? from what? Plastic?
  5. Sir X Loin
    Sir X Loin
    awilson40 likes this.
  6. Mr48chev
    New one on me as It was my understanding that A GM spline was a GM spline.
    A simple solution might be to machine down the hub of a junk 51 wheel and bore out the center of the hub of the Buick wheel and press and lock the turned down Chevy piece in place. It could be locked in with a set screw in a tapped hole across the seam where the Chev Center and the Buick hub mate together much like a lot of bearing collars are locked together.
    squirrel likes this.
  7. Sir X Loin
    Sir X Loin
    The Buick is larger. So much so that the splines don’t engage the Chevy column at all.
  8. squirrel
    Do you have the steering wheel and the steering shaft?
    can you measure them? can you count the number of splines?
    The Chevy should be 3/4" 36 spline.
  9. cadillacoffin
    cadillacoffin
    could you make a key way adapter?
  10. Sir X Loin
    Sir X Loin
    Isn’t 50’s Chevy 11/16-36?
  11. squirrel
  12. chopolds
    chopolds
    from howell, nj
    This might be a good call-out to people "in the know" to get a list going of the different types and sizes of steering wheel mountings, for reference, and links to maybe someone who can make "adapters" if possible.
    Randall and Sir X Loin like this.
  13. gimpyshotrods
    gimpyshotrods
    I believe that's correct.
    I don't know where the switchover is, buy I have run into this, when customers wanted to mix old and new.
  14. Sir X Loin
    Sir X Loin
    From the best I can tell “small GM” is 11/16-36 and “large GM” is 3/6-36. I’m trying to verify this.
    Small being Chevy and Pontiac
    Large being Buick and Cadillac
  15. DDDenny
    You mean 3/4-36 correct?
    Sir X Loin likes this.
  16. gearheadbill
    gearheadbill
    I'd have a real problem using a 'metal' 3D printed part anywhere in my steering system.
  17. Sir X Loin
    Sir X Loin
    I think I can spline the OD if I buy a Borgenson 11/16-36 coupler.
