Calling all paint experts for advice
Discussion in 'The Hokey Ass Message Board' started by Doug520, Sep 7, 2025.
  1. Doug520
    Doug520
    All you paint experts, I could use some advice. I've done some paint work in the past, but I don't have extensive experience and it was quite a while ago. I've got plenty of air volume here on my setup (80 gal two stage compressor) so that's not an issue. I have a gravity fed gun, so I believe equipment wise I'm good to go. The issue in one word is "pearl".
    My car (see avatar) is painted GM ****ernut Yellow with pearl. That's all I know about it as I bought it already built and the previous owner has p***ed away.
    I dinged up the radiator surround and while I can pay someone to do the job I'd really like to give it a go myself. If it comes out terrible I'll just have a pro re-do it. Laying down the primer and the yellow is easy. I can handle that no problem. The issue is the pearl, as I've never done it before. In searching the net, it seems the pearl goes on after the yellow base coat is laid down, with the pearl powder mixed into some clear, and then once that's done then 2-3 coats of clear go over that. I have some powdered gold colored pearl coming. When you look into the paint on my car in the sun, there appears to be microfine gold flake in it, I'm told by multiple people that this is the pearl giving that effect.
    My question is, does the above sound correct as far as how to apply it, in a mid stage coat? How do I determine how much of this pearl I mix into the clear coat to lay it on? What's a good tip size and pressure to start with? How many pearl coats do I put down?
    I know the chances of this matching are slim given my lack of experience with the material, but I figure you learn my trying and making mistakes. This will be fun to try if nothing else. Any information you guys might have would be appreciated. Thanks!
  2. squirrel
    Just a general suggestion, do your experimenting on something besides the car parts...then when you figure it out, shoot the car.
  3. Doug520
    Doug520
    Agreed. I have an old fender laying around, I'll play with that first. Thanks, Jim.
  4. Dick Stevens
    Dick Stevens
    Budget36 likes this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I am moving this to the main board where you will get more views. Go to the paint store and get some test cards. they are used for doing sprayouts to test for color matches. Also know that there are both powder and paste pearls and several different manufacturers . Man it is going to be tough to match. I would start by mixing the pearl real light and trying to sneak up on the color with multiple coats. When I shoot pearls I use blending clear because it is easier to spray and dries faster. good luck, this is not going to be easy. the only saving grace is the grill shell is not right up against anything that is that color so maybe it can be off a little?
    bchctybob, Budget36 and Packrat like this.
  6. jaracer
    jaracer
    I'm kind of in the same boat you are. I decided to paint my Model A because I have painted a few cars back in the day. It turns out that the last car I painted was my race car and I quit racing at the end of 1986; that's not that long ago, right?
    Built a paint booth out of PVC pipe with decent air flow and good lighting. I was using a Sherwin Williams single stage metalic paint. The first small piece I painted looked real good. Unfortunately, on large panels I got very blotchy results and my attempt to fix the blotchy look resulted in runs. Found a paint guy that painted my buddies 34 about 15 years ago (really great paint job). Paid him to repaint it with some 2 stage Sherwin Williams metalic paint. It looks great and was well worth the money.
    Some parts are still in sealer because I gave up trying to make the metalic look good.
    MMM1693, catdad49 and Budget36 like this.
  7. We are taught to do a let down test panel for pearls.
    Lay down the base color on a panel then a coat of pearl, tape off a section, another coat of pearl, tape off another section, another coat of pearl …… then clear coat it
    This will tell ya how many coats of pearl to match the existing color.
    we don’t guess on how much pearl to add to the midcoat in the collision industry
    We have a 3 stage formula. A mixed base followed buy the pearl midcoat stated by the paint code. Lays down like a base coat. The number of pearl coats is determined by the test panel.
    if no paint formula, one way to get close is to have it scanned by an automotive paint store.
    there’s a lot of different flakes and pearl toners.
    Budget36, tomcat11 and Moriarity like this.
  8. Doug520
    Doug520
  9. K13
    K13
    Not to be a downer but without knowing exactly what colour pearl was used originally this is going to be next to impossible for someone who doesn't know how to colour match. Even for someone who does it will be a huge undertaking without knowing the pearl that was used.
    If this is a custom colour with a pearl added over top of a regular colour the camera isn't going to be of much use. It may by some miracle find a match but that is another long shot.
    Wobbly, clem, Budget36 and 1 other person like this.
  10. Dick Stevens
    Dick Stevens
    My bad, the ***le of this thread sounded so much like the other one that I didn't read it and ***umed it was another thread trying to get an answer that you liked better, it has happened enough in the past on other topics by other people.
    clem likes this.
  11. Doug520
    Doug520
    No worries at all. I should have addressed that, you have a valid point. I understand the confusion.
  12. lostone
    lostone
    from kansas
    Anthony is dead on with the "let down" panels, and so is Moriarty with the parts store test panels. The panels are black and white squares, when you can't see the contrasting black and white squares thru the paint you know you have adequate paint coverage.
    And again as said above trying to match pearl without a reference or starting point is going to be really tough. Many different colors etc to choose from with pearls along with the amount used...
    Play with it, use let down panels etc and have fun. The only negative is you can spend quite a bit of money on supplies and still not get it right.
    Your fortunate enough that at least it's not up against another panel...
  13. ALLDONE
    ALLDONE
    could you just use a chrome grille shell???
    clem and Moriarity like this.
  14. K13
    K13
    The other thing you don't know which will add to the challange is whether or not it was even painted as a tri coat or if the pearl was added to the base coat.
    tb33anda3rd likes this.
  15. HOTRODNORSKIE
    HOTRODNORSKIE
    There is so much going on her what was the air pressure , ho many coats, was the pearl in the base paint or clear. THE one good thing is its way up front and not close to another panel you have find out how the pearl was mixed than play around with every thing I mentioned. You could go to a pro and bring a small peace of the car that can be removed and have them come up with the correct formula.
  16. BJR
    BJR
    Something else I haven't seen mentioned, is use the same color primer under the base as was used on the original paint job. A friend of mine painted a car yellow over grey primer, had one part he forgot to paint and used black primer then yellow. The difference was very noticeable.
    2OLD2FAST likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    all of these reasons are why you need to be extremely careful with cars that have custom paint.... @ALLDONE had a good suggestion, just get the grill shell chromed
    ALLDONE and SS327 like this.
  18. guthriesmith
    guthriesmith
    With all the issues of matching a pearl paint especially when you don't know what it is, at least you have distance from any mating parts on your side. That is unless you have a hood... :rolleyes:
    clem, Moriarity and MMM1693 like this.
  19. tb33anda3rd
    tb33anda3rd
    ....or a good time to paint flames/scallops or the like.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Heck, we haven't even seen the damage yet, maybe it could be fixed with pinstriping???
    ALLDONE, Sky Six, SS327 and 1 other person like this.
  21. ALLDONE
    ALLDONE
    so what happened???????????????????
