Hot Rods Calling ALL Pontiac Guys
Discussion in 'The Hokey Ass Message Board' started by hoodwinx454, Apr 24, 2024.
  1. hoodwinx454
    hoodwinx454
    Hey Everyone,
    I'm in the process of working on a 1955 Pontiac Chieftain. I want to do an old school hot rod out of it. It currently has the 287 in it, it runs good and everything but I'm looking to put a bigger engine in it. What engines will bolt in with no modifications? I've heard 55-62 will bolt right in and hook up to my transmission can anyone verify this? I'd like to put a 347 or 389 in it.
    Thanks for the help.
  2. Pontmerc
    Pontmerc
    from Finland
    55-60 bolt pattern is same.
    55-56 hydro bolt on.
    56 was transition year and im pretty sure newer dual couplin hydramatic had different Size Crank center snout.
  3. Pontmerc
    Pontmerc
    from Finland
    With crankshaft or fluid coupling mods you can bolt on 59-60 389 engine.
  4. hoodwinx454
    hoodwinx454
    So 55-60 engine will bolt right in but the transmission will need to be changed?
    Just making sure I’m following
  5. 302GMC
    302GMC
    from Idaho
    We hope you have the hydro - the early selector 3 speed isn't much of a trans for anything but a stocker.
  6. Squablow
    Squablow
    What transmission does your '55 have?
    The '59 389 has one-year-only forged steel rods, which is kinda cool.
  7. Balljoint
    Balljoint
    Wallace Racing has a good interchange chart that covers this.
  8. Crusty Chevy
    Crusty Chevy
    '55 to I believe '58 have front mounts for the engine, not sure if the 59-60 do. You might have to do some work on that end.
  9. hoodwinx454
    hoodwinx454
    pretty sure it’s the hydro it’s automatic column gear selector
