Technical Cam Regrinding: Why the Pointy Lobes?
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, Dec 21, 2016.
  1. wbrw32
    wbrw32
    I agree,,,There is so much about cam set-ups and valve grinding procedure that 99% of these guys would be lost discussing it. I'd bet that none have ever thought that a flathead cam will flex like a torsion bar if using too strong of springs..same goes for using shims for spring height..they think if your springs need -040 shim on one spring,they all do.
    send me your email address.
    falcongeorge and Montana1 like this.
  2. falcongeorge
    falcongeorge
    from BC
    Will do. I'll send a pm, I am still stuck on an iPad.
  3. Montana1
    Montana1
    No, why do you ask? (I don't want to hi-jack this thread) I'll PM you.
  4. falcongeorge
    falcongeorge
    from BC
    Just a quicky answer, I am just looking into the possibility of spray welding a desoto cam and re-grinding it, so I can run a flat tappet, but I am getting mixed messages on Speedtalk about issues with durability.
  5. Chaz
    Chaz
    Why the pointy lobes, Spock?
  6. falcongeorge
    falcongeorge
    from BC
    Maybe the lobes are "Vulcanized"??:p
    zombiecat and Johnny Gee like this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    falcongeorge likes this.
  8. MrCreosote
    MrCreosote
    from USA
    I have a friend that tried spray welding 20 years ago and gave up on it - the weld came off.
    I'm guessing you need the "right" kind of cam metalurgy to start with, the "right" powder, the "right" spray method, and finally the right lobe lifter dynamic loading level (lobe profile). Even for pros, this combination has to be developed empirically for the most part. Would be easy to give up after 6 ruined engines/cams.
    NOTE: I wouldn't be surprised if you got the base metal temp off by 200*, you might not get the correct adhesion. (or is it cohesion.) (And then there is the spray thickness - I'm sure issues there too.)
