Hot Rods cam shaft?
Discussion in 'The Hokey Ass Message Board' started by Ghost28, Feb 11, 2022.
  1. Ghost28
    Ghost28
    have a new camshaft that I removed from a fresh 396 engine. The numbers on the end are as follows 5536 and A145C
    from what I figure it is a L88 big block chevy camshaft. My question were these made as solid lifter only, and if not how can you tell if its a solid or hydraulic style. No lifters came with the short block
  2. saltflats
    saltflats
    from Missouri
    Solid cam will have a clearance ramp on the lobe.
    mad mikey likes this.
  3. Fordors
    Fordors
    If you are sure it is an L-88 cam then it is a solid lifter cam, they only came that way.
    mad mikey, 2OLD2FAST and Almostdone like this.
  4. Ghost28
    Ghost28
    Thanks guys. i am fairly sure that it is a L88 cam after researching the numbers, it was new in this 396 so i took it out and bought a milder hydraulic cam for street use. Not sure if I will ever use it, but I might hang onto it for awhile. Thanks again
  5. bobss396
    bobss396
    I ran an L88 cam in a 396 powered stock car and liked it a bunch. It had a decent idle and would get us past the cam rule.. at least not warrant a check at the track.
  6. sunbeam
    sunbeam
    Maybe you ought to sell to this guy and find another camhttps://store.tracyvette.com/item/1692/
  7. 55blacktie
    55blacktie
    I had an L88 cam in my 69 L78 SS 396 Chevelle/w M22 "Rock Crusher" 4-speed. It had a very rough idle (rump, rump), but smoothed out where driveability on the street was not a problem. It did leave a raw-gas smell in the garage and rubber wherever it went. In other words, it was fun.
