Technical Cam Specs
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jan 21, 2022.
  1. johnfin
    johnfin
    from Florida
    Is there an inexpensive was to find out what cam specs are. Its installed in an engine. I was thinking a degree wheel and dial indicator.
    Johnny Gee likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Soft test springs would be a plus.
    Elcohaulic likes this.
  3. RmK57
    RmK57
    Lift could be measured from the rocker, if it's a solid lifter with 0 lash.
  4. greybeard360
    greybeard360
    A dial indicator and degree wheel is all it takes to figure it out when it is in the motor. You can map out the intake and exhaust closing events and find the lobe lift. The only thing you won't be able to figure out is the lobe profile. Make sure you check opening and closing events at .050" lobe lift.
    loudbang and Johnny Gee like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s the reason I mentioned test springs over normal valve springs. That way hydraulic lifter are less likely to bleed down.
  6. johnfin
    johnfin
    from Florida
    Do most cams have a number cast on them that I could see from below (crank area) looking up?
  7. ottoman
    ottoman
    from Wisconsin
    Nothing that will ID the cam grind
