Cam Won't Come Out!!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Jul 19, 2012.
  1. Greaser Bob
    Greaser Bob
    Help!! Before I screw up the bearings, I need help. Lifters, intake, distributor, timing chain, all out of motor. Oh yah-it's a late seventies SBC. Gently pulling it forward with timing gear back on it for a handle. It only slides out about 1.5 inches or so. Spin it slowly/gently-still won't come out!
    Any takers????!!!!!
  2. squirrel
    fuel pump pushrod?
  3. 60galaxieJJ
    60galaxieJJ
    Are you sure your pulling it perfectly straight? That's the only thing I can think of
  4. lexington
    lexington
    Squirrels right you gotta remove the fuel pump rod.
  5. 32ratsass
    32ratsass
    Yeah! What Squirrel said!
  6. legendrat72
    legendrat72
    i agree is the fuel pump already out of the motor? the push rod on the fuel pump is run off the the cam and with out that being out no matter what the cam wont come out.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yep, did you remove the fuel pump is what Squirrel is refering to. Push rod will slide down by it's self.
  8. ironpile
    ironpile
    Me thinks Squirrel got it right.:D
  9. PASTDUEBILL
    PASTDUEBILL
    Not answering. Might be out in the shop pulling the pump.
  10. nwbhotrod
    nwbhotrod
    from wash state
    Come on we have all been there. I beat on a flat head water pump for two days befor I saw the bolt on the inside
  11. either squirrels right.... as usual or your bearings are way shot
  12. MISCONSTUDE
    MISCONSTUDE
    What squirrel said.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I wonna know how he got the lifters out before the intake and the intake before the distributor ;).
  14. Buzznut
    Buzznut
    Been there...easy mistake to make.
  15. don't count on it sliding down on its own, years ago, I found out that was not always the case......
  16. rld14
    rld14
    I did dumber... I flipped out to a degree after changing rockers on my Lincoln.. Had the valve cover off checking oil flow and it was backfiring...
    Oh ****, what did I do?
    I zip tied the spark plug wires in a way that they were cross firing. Doh!
  17. percifab
    percifab
    from Dixon,CA
    Fuel pump rod. Atleast I'm not the only one.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Geez, ok!, let me put it this way. Theres no need to remove the plate behind the pump, the rod should slide down on it's own. Use a flash light if needed to see if said rod has slide down. If not, get back with MoparMan.
  19. Greaser Bob
    Greaser Bob
    HOLY ****!!! I tried pulling the one out of my spare motor and it came right out-tried it again on my motor in car.Nope. Then looked closer at the lobes on the one I pulled out of the other motor. There's a WAY rounded off lobe on that one, toward the front. WAIT-that block has no FUEL PUMP on it!
    Pulled the pump, tried it, came right out!
    Have a victory smoke.......come in the house and tell my totally uninterested daughter......sat down to the hamb......and if I had only sat here a little longer the first time-SQUIRREL WOULD HAVE FREAKED ME THE HELL OUT!!!!
    is there any question why I love you guys????????
    Thanks again, next time I'll wait for the replies!!!!!!!!!!!!!!!
  20. squirrel
    lmao...you should have seen me the first time I tried to take the heads off a 283 when I was 14. Did you know there are some more bolts hiding under all that sludge?
  21. 60galaxieJJ
    60galaxieJJ
    Lmao always!
  22. Mr48chev
    I've seen a couple of heads over the years that were "removed" with that row of bolts still in the block. Word was that the guy removing one of them needed a large pry bar to break it loose.
    Good to see that you got the cam out Plowboy13. That's called an educational experience.
  23. ;););)
  24. Ditto.
  25. Greaser Bob
    Greaser Bob
    Now tonight my new lumpy-er cam goes in!!!!WoooHooo!!
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The Distributor is 180* off ;)
  27. southern thunder
    southern thunder
    yeah, what squirrl said, I beat the hell out of a cam trying to get it out, then realized the fuel pump rod may be the problem. duh!! after taking the fuel pump off, rod slid down, out came the cam. stupid me.
  28. Greaser Bob
    Greaser Bob
    That's funny **** right there!!!! But that happened to me LAST time-and the memory is still fresh:rolleyes:
  29. seabeecmc
    seabeecmc
    fuel pump pushrod?
    What squirrel said.
    Fuel pump rod.
    Ditto.
    Can't help but wonder if this may be a HAMB record of some sort. Folks getting their post counts up, I guess. Ron
  30. Greaser Bob
    Greaser Bob
    Ding Ding Ding!! But tonight I recovered fast!
