Camaro clip and the 454
Discussion in 'The Hokey Ass Message Board' started by fleetsidejeff, Mar 2, 2013.
  1. fleetsidejeff
    fleetsidejeff
    from Nebraska
    Working on the 59 apache with a camaro clip. its a GenIV 454 and the alternator brackets and the a/c brackets were hard to find. (got them). Now the issue is the pulley from the power steering does not allow enough room for the original steering box from the camaro to be used. Wondering what anybody has done for this. Wil the vega steering box be strong enough for the weight of the motor? can i or is there a way to use this configuration?
  2. txturbo
    txturbo
    I have a 79 Trans Am clip in my 55 with an 89 5.7 with the serpentine belt setup. My PS pulley was hitting the steering box also so I moved the motor mount brackets back 3/4" and welded them down.
  3. CJS
    CJS
    The smaller 605 steering gear may give you some clearance. The 605 box was used on GM metric stuff after 78. Some of them may have different fittings so hoses may have to be changed.
  4. JAWS
    JAWS
    That or it wouldn't be hard to adapt a rack to it.
  5. gimpyshotrods
    gimpyshotrods
  6. fleetsidejeff
    fleetsidejeff
    from Nebraska
    good stuff gentlemen....thank you!
