Camaro clip
Discussion in 'The Hokey Ass Message Board' started by myforty40, Sep 30, 2012.
  1. myforty40
    myforty40
    from Hebron, in
    I've bought a 56 truck that's has a Camaro front clip and 10" rear end. How do I find out the year of each one? Your help is appreciated
  2. George/Maine
    George/Maine
    I think the 67,68,69 is rear steer,70-79 front steer with 2 piston caliper,after that think calipers are small one piston.
  3. IIRC, pre 70 Camaro stubs use a "double" crossmember and are rear steer as George pointed out. Nova stubs are rear steer up through 73, I believe.
    Did you mean "10 bolt" rear? There are 2 main variations. If the cover is almost perfectly round, it's an "early" 10 bolt. If it has a squared off cover, it's more likely a 78 and up "metric" axle.
  4. drptop70ss
    drptop70ss
    from NY
    Pictures of the clip and steering box location will help identify the clip. Picture of the rear end cover will help identify the rear.
  5. squirrel
    67-69 camaro and 68-74 nova are rear steer. Later are front steer.
    There are at least three variants of the 10 bolt rear. Early ones were the 8.2", starting around 71 they got the 8.5". The 7.5" was not used in cars that had front subframes.
  6. 70 to 72 camaro clips have different size upper control arm bushings. 73 to 81 are the same size.
  7. myforty40
    myforty40
    from Hebron, in
    Thanks for the help. I appreciate your help.
  8. myforty40
    myforty40
    from Hebron, in
    Thanks for the info
  9. Shane Spencer
    Shane Spencer
    i had a 7.5" 10 bolt in my apache. there total ****tt. i have a camaro clip in it as well, it gives you a ton of options with the front suspension whether it be bags or what have you. hard to beat really. do yourself a favor and ditch the 10 bolt if its a 7.5"
  10. myforty40
    myforty40
    from Hebron, in
    Why didn't you like the 7.5"?? I'll check this out, thanks
  11. myforty40
    myforty40
    from Hebron, in
    I finally got under this truck and found it to be a 8.5" 10 bolt rearend. 41 on the ring and 17 on the pinion. Man that's low. Thanks fro your help.
  12. myforty40
    myforty40
    from Hebron, in
    it turned out to be a 8.5" 10 bolt rearend. With a 2.41 gear ratio. Thanks for your ***istance.
  13. myforty40
    myforty40
    from Hebron, in
    Your illustrations helped a great deal. I have an 8.5" 10 bolt with 41 teeth on the ring and 17 on the pinion. Any idea what this might have come out of? Maybe a truck?? thanks for your help.
  14. bobkatrods
    bobkatrods
    from aledo tx
    There is a G M part number stamped into the upper control arms , you can cross ref, from them,, .
  15. treb11
    treb11
    There will also be an axle code on the top of one of the housing tubes near the center chunk. That could help figure out the origins, because I'll bet they both came from the same car.
  16. 2.41 is a highway gear. It probably came out of the same Camaro/Firebird the front clip did. Is it 61" or so wide?
  17. myforty40
    myforty40
    from Hebron, in
    Het thanks. I got those numbers/”letters. Have any direction i can go to to find out what they mean?? Thanks again
  18. myforty40
    myforty40
    from Hebron, in
    Yes it's 61". Thanks
  19. myforty40
    myforty40
    from Hebron, in
    Ok I got the info. On the rear end is 1148. On the control arms is (p***enger side) G22J8R and on the drivers side is J7118L. Have any ideas??
  20. myforty40
    myforty40
    from Hebron, in
    Re: Camaro clip
