Please help me. I need a professer of cam-oligy,to ID a cam for me. Erson hi-flo B114s2. 108 684-R. Can I****ume 108deg.lobe centers .684 lift? can it be used with hyd. lifters? If not what's the recomended lash? I have so many questions,Hamber's will supply the answers. Thanks, glenn
Make it easy on yourself. Go to http://erson-cams.com/ and either look it up or contact their tech line. They will be more than happy to give you the info that you need.
COuld you look at the number on the cam again? My reference material shows all the "114" series cams are for Pontiac Iron Duke 4-cylinder engines. While that'd be cool, I'm doubting that's what we're looking at. By the way, the P/Ns on erson stuff has little (if any) reference to the cam dimensions. You may want to contact Erson directly through www.mrgasket.com or through their phone line at (775) 882-1622. I wish I had more to share! Scotch~!
