Technical Can’t find a coil spring
Discussion in 'Traditional Customs' started by drew1987, Apr 7, 2020.
  1. drew1987
    drew1987
    Hey all!
    I’ll be needing a coil spring roughly:
    4.90” ID
    6-7 turns
    “Square” ends
    350lb rate
    1650 load
    11” free height.
    I’ve searched Moog catalog and got close but way too tall. Can’t find any vehicle with anything similar
    Help would be appreciated
  2. spook498
    spook498
    Black_Sheep likes this.
  3. drew1987
    drew1987
    I did. He said $1600-2500 custom springs. Talked to someone else thats $320ish but was hoping for a junkyard take off or $50-90 set of regular off the shelf springs. Total bummer if its got to be customer. Money just got REALLY tight
  4. guthriesmith
    guthriesmith
    What are you needing it for Drew?
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Why the 4.9" I.D.? Lots of 5" O.D. springs in the range you are looking for. Speedway, AFCO etc.
  6. jimmy six
    jimmy six
    Cut the tall ones.
    partssaloon and guthriesmith like this.
  7. lowrd
    lowrd
    Try contacting Jamco, they listed a set for 49-54 chevs on sale? Don't know prices.
    There is a thread on here about stepping the lower A arms if you need to go low.
  8. Mimilan
    Mimilan
    The load rate is unusual. Is that the spring load or the vehicle load on it.
    1650 load on a 350 lb/in spring = 4.7"
    This would be very normal on a MacPherson strut suspension. But not an A-Arm suspension with a larger motion ratio.
    4.7" load on a late GM suspension = 7" [which is soft] and would have a 155 lb/in wheel rate
    TA DAD likes this.
  9. drew1987
    drew1987
    Thanks for all your responses. Well actually it’s for a project that’s not welcome here :( but you guys are the most knowledgeable group on the web when it comes to figuring out what’s out there and putting it together to work so I went for it and asked. I can probably work with 5.0” but I need to watch my od. It’s not for the 50 front end those are like 3.5” if springs
    I’ve been considering making all the plates and brackets and going with standard 2500lb air bags. They are like $100 and ride like a dream. Was hoping to Just throw in some junkyard springs and live happily ever after but doesn’t look good
  10. mark latham
    mark latham
  11. drew1987
    drew1987
    Wow that is very close, the first one I mean. I don’t think I can clear the ID but that same spring in a 5” would so it I think
