Can A 9 Inch Ford Take The Torque Of A 454?
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Aug 8, 2013.
  1. powrshftr
    powrshftr
    In my experience,if it came from a 302 pickup,it should be a 31 spline,3.50 geared open diff,but as the OP stated,somebody may have been inside it at some point.
    I would be willing to bet he has 31 spline axles though....
  2. NOPE :rolleyes:
    It will hold more then you will probably be throwing at it.
  3. Gus68
    Gus68
    from Minnesota
    If you take it to the track with street tires, I gar-o-teee the next time you go back you will have slicks. Either new or borrowed or used, but you Will have slicks. Ex. "She ran 13.01s, I think with slicks she'll run in the 12s" It's like a drug, every time you need more!!!!
    olscrounger likes this.
  4. HahaHAHA! :D Best answer yet.
  5. 1931modela
    1931modela
    from montana
  6. DeucesAllin
    DeucesAllin
    NECRO THREAD:
    I am resurrecting this tread here because options and technology changes... for instance a man can now find fabbed 9" housings with axles for half of what bare fabbed housings cost a few years ago.
    I am looking at buying full float with 0.188" wall housing, 3" tubes, and a new fabbed center section... the money I save on not buying a bigger name housing would be spent on a nice aftermarket center....
    Rig is a 3700lb race weight 2wd truck with iron heads... 29" DRs, th400... soft launching/short shiftong first and pouring it on in 2nd and 3rd...
    Should be 625whp and 550 or so tq... trapping at 6300 or so.
    What do you think about a new US made .188 wall 3" tube full floaf housing in this scenario?
    W
    Sent from my SM-J700P using Tapatalk
  7. DeucesAllin
    DeucesAllin
    Well... the housing is actually .375" wall.
    I guess I have my answer.
  8. Did the 9 3/8ths case out of a 72 big block LTD station wagon have the weakness at the pinion that you wrote about? I plan to narrow one and put an Eaton center to run behind my warm 454.
    Bob
  9. mgtstumpy
    mgtstumpy
  10. Larry T
    Larry T
    Here's a rearend with a fabricated housing that I put together for a customer, not a Ford piece in it. It wasn't cheap. koby rearend 002.JPG
    mgtstumpy and saltflats like this.
  11. MMM1693
    MMM1693
    Give John a call at Johns 9in Factory. He will give you good honest info even if you don't buy from him. But after dealing with him a couple times , I don't think I'd go anywhere else.
  12. DDDenny
    Those stock nose pieces don't like healthy 502's either.
    Even with street tires.
  13. Pretty long jump from .188 to .375. I am a little confused.
    Soft launch short shift then pour it on in the next two? Are you racing or playing pitter pat?
    I have thrown more than that at a stock 31 spline rear, the weak spot is the pinion support.
  14. Back in the Day's when I was Racing I ran a 64 SS Chevelle L-88 Steal Heads on
    my Car that Weight was 3430 lbs.
    I ran a 4 series GM Carrier with 5:14 gears M22 Trans & Moroso Spider's
    Henry Axle's & I ran 13 1/4" Ripple Slick's
    I came out of the Hole at 850 rpm & Shifted at that rpm
    Never Had a Problem with the Rear!
    Just my 3.5 cents
    Live Learn & Die a Fool
  15. 850? I got an idea that your old Chevelle shifted a couple of thousand higher than that. LOL
    We used to look for the Eaton Steel carrier when we were running a 12 bolt.
    On a heavy car or one that was running a lot of motor we didn't run the Dana 60 we all preferred the ****er 60. I am sure that it was a personal thing more than anything else.
  16. Here is a Picture of the Car I was not sure it would Come Out
    in my answer.
    Just my 3.5 cents
      9.8 KB
  17. I forgot to Add a Couple of zero's you know when you Get Old
    you forget some thing's
    Just my 3.5 cents
  18. I knew that but you were soooo available. LOL
  19. They use to Call my Car the screaming Big Block
    I did a Couple of 10,000 Blast but I only went to 9800 even the Block
    was Design to go 10.000 I could not do it
    And they would announce it on the Loudspeaker's
    so people would pay the Extra $5.00 to come into the Pit's
    to look at the Car's
    Just my 3.5 cents
  20. big john d
    big john d
    from ma
  21. big john d
    big john d
    from ma
  22. big john d
    big john d
    from ma
    ebay right now 9 inch n case new usa made gears and a 28 or 31 spline spool 500dollars delivered
  23. DDDenny
    I'm thinking there's some rounding off of numbers here as the thickest Ford 9 inch housing tubes came on the 57 F-100 housings and they are 5/16" (.312).
    mgtstumpy likes this.
  24. That's the truck housing isn't it?
    My last real hot rod 9 I cut to 54" and used 3x.1875 mechanical tubing for the axle tubes.
  25. olscrounger
    olscrounger
    They will handle a lot. Friend has a 9" built locally. It is in a chevelle with a 585 big block all motor. It leaves hard (1.22 60 ft) and has run a best of 8.76 at 152. Tears it down as needed every season-no failures or problems.Helping him upgrade to a 632 with more HP.
    A Nova with a rear from the same place runs more HP and in the 7's-no problems.
  26. DDDenny
    Affirmative, 57 only, 1/2 ton only.
  27. Larry T
    Larry T
    F-150s came with .225 thick 3.25 axle tubes. They're kind of a pain to put brackets on, but I like 'em.
