Can an engine run too cool????
Discussion in 'Questions & Suggestions' started by sacred_piston, Jul 23, 2004.
  1. sacred_piston
    sacred_piston
    I have a 67 chevy C-10 with a 72 350 4-bolt main and I was having overheating problems so I figured out it was rad since everything else is new. I was running in city traffic on scorching hot day upwards of 225 degrees (not moving) with 185 thermostat. I bought an aluminum rad and dropped stat to 160. Problem solved I am running steady 155-160 on really hot day sitting in alot of traffic it went to 180. Can it be bad to run at a low temp like 155-160? Someone told me it is. If so I was going to put the higher 185 stat back in.
  2. Mutt
    Mutt
    Yes, it is bad to run too cool. Use a 180 thermostat. The motor needs to warm up to be efficient.
    I would also suggest that you post questions pertaining to cars on the Hokey**** Message Board, as THIS forum is for questions about the operation of the board, not cars. It would also be advisable to give an intro on the HAMB, as I see you haven't done yet.
    Mutt
