Can any one ID these wheels?
Discussion in 'The Hokey Ass Message Board' started by XtechX, Feb 13, 2015.
  1. XtechX
    XtechX
    from Edmore, MI
    I found these wheels at a swap meet $20 for the pair. I thought they may work well on the front of my 29 coupe but I see it's hard to find wider rear 16" wheels for the back that are 5 x 4.5 bolt pattern.
    These rims are 16 x 4 and are 5x4.5. They have numbers on the inside of the rim.
    BUDDRIM 16x4.00 44755-E-1 7 46
  2. alchemy
    alchemy
    Probably a Mopar of the late 40's.
    If you might want another hard to find wheel with a 4.5 pattern that WILL take a 40's Ford hubcap, look for some wheels from an International pickup of the later 40's. Different sizes are available.
  3. 31Dodger
    31Dodger
    Looks like my 1946 Dodge wheels. I believe they went to 15" in 1947.
  4. wbrw32
    wbrw32
    Is your 29 Coupe 5-4.1/2 Bolt circle???? If so someone has changed from stock..Stock is 5 on 5 1/2
  5. Squablow
    Squablow
    Yeah, 40-47 Dodge/Plymouth/non-Imperial Chrysler. I was under the impression Mopar went to 15" in '48 but I could be wrong.
  6. XtechX
    XtechX
    from Edmore, MI
    The guy I got them from said they were in the trunk of a 39 mercury. That probably doesn't mean anything though. It does have the number 46 at the end of the inside number stamping. I'm going to be running after market 37-41 spindles with the 5- 4.5 rotors not the stock ones.
  7. XtechX
    XtechX
    from Edmore, MI
    What all wheels will take a 40 ford center cap and what do the rims look like that they will fit on. That's the look I want.
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    just sold Norwell a pair of '49 Ford wheels...16x4 with 5 on 4.5 bolt pattern
    kidcampbell71 likes this.
  9. 31Dodger
    31Dodger
    I missed the fact that it has no holes between the lugnut holes....NOT MoPar.
  10. roundvalley
    roundvalley
    I would think the hub cap clips would be the best clue.
  11. alchemy
    alchemy
    Am I invisible? Like I said up above: You need some International pickup wheels. They look exactly like '48 Ford wheels, except the bolt pattern is 4.5". The Ford hubcap snaps right on. They come in different sizes and offsets, so make sure you get a matched pair.
  12. Hnstray
    Hnstray
    from Quincy, IL
    While I am not sure of the full year model range, I do know for a fact that some Dodges used wheel studs with nuts, not wheel bolts. I did notice these do not have the locating pin holes, but everything else about them 'says' Mopar, so I attributed them to Dodge.
    Ray
  13. gecko54
    gecko54
    from Sumner, WA
    What's the back side look like? If it looks like the front great, if it's "belled" you may have caliber clearence issues.
    Just a heads up.
