Can anybody calculate, this odd size gas tank, volume.
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Jul 23, 2008.
  1. Chris Casny
    Chris Casny
    In my coupe, plan on making a tank, that fits perfectly behind the seat and gives me maximum trunk space.
    How much gas will this thing hold??????
    36" wide, 18" tall, 16" deep with a angeled back.
    Thanks, Chris
    Here is a little sketch, I made.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  3. Figure the volume in cubic inches and devide by 231 = gallons.
    You may have to guess at that angled part....
  4. Chris Casny
    Chris Casny
    Great, thanks.
  5. chaddilac
    chaddilac
    That's it! I came up with 33.66
  6. TudorJeff
    TudorJeff
    Or think of it as $143 a fill up :)
  7. BriggsBodied28
    BriggsBodied28
    (corrected 7/24/08......formulas were right but I had punched in the wrong numbers)
    I broke down the problem this way:
    1) isolate a rectangular section L=18" W=8" H=36"
    2) volume of the rectangular section is L*W*H=5184 in^3
    3) convert to gal => 5184 / 231 = 22.44 gal
    4) remaining right-triangle prism with Base=8" Height=18" and L=36"
    5) volume of the prism is 1/2*B*H*L = 2592 in^3 = 11.22 gal
    6) summing the two parts 22.44 + 11.22 = 33.66 gal
    quite a bit of fuel.
    =Chad J.
  8. Da Tinman
    Da Tinman
    Bigger than your bladder, thats all that matters anyway right???
  9. propwash
    propwash
    from Las Vegas
    Briggs is on the right track, but he's made a basic math error. His treatment of the isolated rectangular box is good. But he divides the entire "prism" as he calls it by 2, when only the base x height needs that function, then you multiply that by the length. In other words:
    8 x 18 x 36 = 5184 cu in
    8 x 18/2 x 36 = 2592 cu in
    5184
    2592 added together equals 7776 cu in. times .00433 (conversion factor from cu in to gal) equals 33.6701 Gallons as noted in one of the first answers.
    and I told my math teacher I'd never need this stuff...
    dj
  10. RichFox
    RichFox
    If you put two of them togeather wouldn't it be 24 X 18 X 36? Then you just do the math and divide by two?
  11. ST. 515
    ST. 515
    from TEXAS
    I got the same... 33.66gal
  12. I guess I'm mathmatically lazy. I'd build it, seal it, fill it with water, then start filling 5-gallon buckets with the water and see how many I filled.
  13. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Hey, dont make it so easy, some if these math whiz's are trying to impress us!
  14. There's a formula for odd shapes, but there's a slight amount of approxiamating involved. But, I come up with about 31. I'm a lousy guesser
  15. Chris Casny
    Chris Casny
    I actually need that in "Imperial Gallons" not US gallons:D:D:D
    Just kidding, thanks for the info, I even got Groucho to use his calculator.
  16. Royalshifter
    Royalshifter
    Moderator
    Now I feel mathematically fucking stupid.
  17. Looking back, Rich Fox had the best answer.
  18. Overtons might have a ready made tank in that size? www.overtons.com
    Hmm, just looked, they dropped the one I was thinking of and the prices went up in the last year or so!
  19. hotrod40coupe
    hotrod40coupe
    I am a math teacher and these calculations are correct. Propwash, you get an A+. If you want Imperial gallons it would be 28.03 Imperial Gallons.
  20. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Thomas Eddison hired a fresh collage grad . He gave him a light bulb glass fixture and said tell me the volume of it.
    This young man did all the math and spent quite alot of time to come up with a number. It was wrong Eddison said fill it with water and pore it into a graduated container. I like simple
  21. Unkl Ian
    Unkl Ian
    For a simple shape like that,there should be no guessing involved.
  22. I hear ya! I almost always have to stop for a piss sooner than I need to stop for fuel.
  23. Sloppyseconds
    Sloppyseconds
    from Pasadena
    Thats alot of fuel.... remember with that many gallons its gonna weigh alot... so spring it correctly too!!! :) My tank is small but hangs off the back half and surprizingly lowers the car alittle filled compaired to empty... but maybe thats cuase I have so few leafs in the rear
  24. R Don
    R Don
    from KC
    It is about 33.7gal. But before you start cutting metal, I think that 19-1/4" actually needs to be closer to 19.7" if you want the opposite side to have 2 right angles.
  25. Goztrider
    Goztrider
    from Tulsa, OK
    My sixth graders learn this one.... you essentially turn the thing into a rectangle.
    Formula for area of a trapezoid = (b1 + b2 / 2) x height
    Take the top and the bottom measurements, add them together, and then divide by 2.
    In this case, 8 + 16 = 24... Divide 24 / 2 = 12
    So now, take the simple volume formula L x W x H (12 x 18 x 36) = 7776 cubic inches
    Divide 7776 / 231 = 33.66 gallons
  26. tjm73
    tjm73
    33.67 gallons?!?!?!? What are you building a cross country runner??? If you only got 15 mpg you would have more than a 500 mile range. That's like ten hours of driving.
    A quick google says gasoline weighs 5.8 to 6.5 lbs per gallion. That's a load of ~195-220 lbs in fuel. You might want to design the fuel tank to sit low in the car to help handling when loaded. If it's mounted high it'll have a negitive effect when full.
  27. BriggsBodied28
    BriggsBodied28
    I stand corrected with my previous numbers. I edited the post....my formulas were correct but I had punched in the wrong numbers. Either way - I made the wrong answer. 33.67 it is.
    As my undergrad professor used to say to a class I took on static structures, "You build bridge. Bridge fall down. NO PARTIAL CREDIT!"
  28. Da Tinman
    Da Tinman
    20.91-ish
    Add the top and bottom, 5.25 and 10.25, then divide by 2, 7.75
    Add the front and back, 14 and 15, divide by 2, 14.5
    7.75 X 14.5 X 43 = 4832.125
    Divide that by 231 = 20.91
  29. super plus
    super plus
    33.7 Gal If you haven't already I would be puttin in some kind of baffles to stop the motion of the fuel , not to mention the noise right behind you
  30. ibcalaveras
    ibcalaveras
    Here's one I drew up a few month ago for my One Eyed Roadster. It's in DWG format. If someone can convert it to PDF, it would be helpful. Other wise you will need autoCad to see it...
    It's pretty much the same design as the one shown above, just a little smaller.. El Gringo is going to build it for me...
