ive got a 53 belair im putting a 292 6cyl 400 turbo in it and i have clifford research headders for it but when i put the motor in the headders wont fit because of the steering linkage any tips or tricks to help would be appreciated thanks in advance
Are you running the 52-0011 http://www.cliffordperformance.net/...de=CP&Product_Code=52-0011&Category_Code=C250 set or the 52-0768 set? The 52-0768 set isn't going to fit that ch***is at all. If you have the 0011 set do you have the engine setting in the engine compartment where it should and not too far forward?
