Technical Can anyone ID this intake and carbs?
Discussion in 'The Hokey Ass Message Board' started by deto, Dec 2, 2014.
  1. deto
    deto
    I know its for an SBC but right now that's all I can decipher. thank you guys.
  2. timwhit
    timwhit
    Does it have any GM dates/numbers?
  3. gimpyshotrods
    gimpyshotrods
    Sent it over, and I will figure out exactly what it is.
  4. old drag dad
    old drag dad
    from texas/pa
    What does the back of the manifold look like?
    from the looks of the air cleaners it may have ben on a boat.
    Has it got a distributor hole in the back of the manifold???
    With that breather in the front it almost looks like somthing AMC.
  5. old drag dad
    old drag dad
    from texas/pa
  6. deto
    deto
    I don't have it in my possession. I will find out the numbers tonight when the guy selling it gets home
  7. deto
    deto
    Haha
  8. deto
    deto
    What about the carbs?
  9. big duece
    big duece
    from kansas
    Looks like sbc aftermarket for sure. Only the 348 had a 3x2 stock intake. Carbs are 2gc, deeper looking will tell if they are from single application, or 3x2 set up. The 3x2 set up, had no idle circuts on the front and rear carbs.
  10. I believe it's an Edelbrock C ___ (can't remember the numbers), they made two different versions, and Rochester 2GC carbs. If the front and rear don't have chokes or idle circuits they might be factory tri-power carbs
  11. deto
    deto
    Are there any external clues on the carbs to tell me if they are all singles or if they are set up for a 3x2 set up?
  12. deto
    deto
    If they're factory tri power carbs what would they be worth?
  13. gimpyshotrods
    gimpyshotrods
    Seriously, it is an Edelbrock. Look at the heat riser. Right there on it there is the model number. As has been mentioned, it starts with a C:
  14. Looks to me like all 3 carbs have choke linkage.
  15. gimpyshotrods
    gimpyshotrods
    The modern one is a C-357-B, which is nearly visually identical, save for a few minor casting differences, and the addition of a couple of manifold vacuum ports.
  16. deto
    deto
    I just got a better pic of it from the seller. Its a Weiand
  17. gimpyshotrods
    gimpyshotrods
  18. gimpyshotrods
    gimpyshotrods
    I'll be damned. Did you score it?
  19. deto
    deto
    Meeting up with him tomorrow...
  20. gimpyshotrods
    gimpyshotrods
    Good luck! Hope you get it!
  21. deto
    deto
    Me too. What do you think it's worth?
  22. Diavolo
    Diavolo
    I don't know much but are those flame arrestors instead of air cleaners? Might have come off a boat if it makes a difference.
  23. 24riverview
    24riverview
    Not actual tripower carbs, you can tell by the throttle levers and the choke fast idle cam linkage. Doesn't mean they can't be made to work but should lower the value some.
  24. gimpyshotrods
    gimpyshotrods
    I've seen the manifold alone go for $400+. Whole setups, in good working order, could fetch a grand, or more.
  25. deto
    deto
    OK great info. Thank you.
