Technical Can anyone id this?
Discussion in 'The Hokey Ass Message Board' started by Dooce, Apr 14, 2018.
  1. Dooce
    Dooce
    As above, can anyone tell me what this is from? Got it in a parts lot of a bunch of axles and trying to decide if I should use it on my t coupe/ a frame [​IMG] [​IMG][​IMG]build
  2. 49ratfink
    49ratfink
    those brakes could almost be 49-54 Chevy. what's the bolt pattern?
  3. Mr48chev
    It's too damned dark to go out and look at the drums and backing plates on the 52 F-1 ch***is I have out here.. As 49ratfink said those sure look like 49/54 Chevy drums though. What is the lug bolt pattern?
  4. X38
    X38
    Axle looks 33 to 6, brakes not Ford so I have no idea about them.
  5. squirrel
    51-54 chevy brakes, not 49-50. If that's what they are. looks like it could be.
  6. deathrowdave
    deathrowdave
    from NKy
    I’m thinking Econline brakes , axle has been identified . Determine the bolt pattern will help , identify the brakes . Chebbies , I have used from that era had bolt on steering arm and early Ford spindle either round or square . Try to identify bolt pattern , it will be a big help . Maybe Chebbie early van ?
  7. deathrowdave
    deathrowdave
    from NKy
    I expanded the photo a bit , are the steering arms bolted between spindle and drum ? If so it very well may be early Chebbie
  8. 49ratfink
    49ratfink
    here are some crummy pics of what I am pretty sure are 51 Chevrolet drums-slash-hubs. it was dark and scary over on that side of the shop where I took the picture. I stepped in something wet. this is all you get.
    51-52-53,, almost for sure.
  9. gimpyshotrods
    gimpyshotrods
    I believe that you are correct.
  10. squirrel
    chevy used the same front brakes on cars from 51-54.
  11. doyoulikesleds
    doyoulikesleds
    looks like a ford axle with chevy spindles and brakes
  12. Dooce
    Dooce
    OK, thanks everyone. gives me something to look into. it came with a 35-36 banjo and rear wishbones so I imagine its from the same car then.
  13. Fordors
    Fordors
    Agreed about Chevy brakes and spindles. The axle had to be bent to correct the camber, Ford king pin inclination is 8* and Chevy only 4*. Also axle was either bored to accept Chevy king pin diameter of .867, or some guys use a Ford k/p set and make custom bushings from bearing bronze for the spindles.
    Hnstray likes this.
  14. Dooce
    Dooce
    Ok, thanks. I'll set it aside for now until I get a chance to tear into it and see what's been done. Was this a common thing to do?
  15. Bruce Lancaster
    Bruce Lancaster
    There was a HUGE article on these early/strange brake swaps in the old HAMB tech archive which would help you figgerout bending specs, what bearings are in there, etc. Anyone have that?
    My original book with that is in parts unknown right now. Original was in a Ford book of articles collected by I think the old "Rod Action" magazine, perhaps mid 1970's vintage.
