Projects Can anyone identify this steering box
Discussion in 'Traditional Hot Rods' started by Steve Cooper, Jul 14, 2022.
  1. Steve Cooper
    Steve Cooper
    I believe it’s a 32’-34’ Ford, but may be wrong. It has a 3 tooth steering sector. I also believe it had a 3 bolt flange for the frame, but was cut off and a 2 bolt flange braised in its place so it would fit a Model-A.
    I want it rebuilt, but I don’t know which steering box it is, thanks.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    @alchemy to the courtesy phone please.
  3. Early Fords had a electric switch at the bottom of the box that was rod activated. I dont see where this box does. The fill plug is in a odd place on the side.Most Fords had one on the top side. Im guessing its not a Ford,but may have been modified to fit one.
  4. rusty valley
    rusty valley
    Looks like it was originally a cross steer box, note the fill cap on the side.
  5. Mr48chev
    I'm thinking it was a cross steer box converted to side steer. unknown steering box.jpg
  6. Mr48chev
  7. squirrel
    maybe? it had some surgery
  8. Fordors
    Fordors
    For sure, you can see where a flange was brazed back on by the sector shaft.
  9. squirrel
    and the mounting ears cut off the main housing?
  10. Fordors
    Fordors
    Now that you mention it, yes Jim for sure, I didn’t catch that right away.
  11. rusty valley
    rusty valley
    37-48 ford is my guess
  12. alchemy
    alchemy
    Two bolts holding the end plate on? I’m going to guess a 36 Ford.
  13. rusty valley
    rusty valley
    If my guess is correct, I believe the trick was to use a right hand drive worm and sector to have a bottom throw pitman arm. Otherwise, the lefthand worm would require the pitman arm to face up for side steer
  14. rusty valley
    rusty valley
    If its 36 ford, it would have a bearing on the sector shaft...one year only
  15. Steve Cooper
    Steve Cooper
    I think all of your responses are possibilities. This is in a 30 Ford roadster rat rod. It had a 49 Olds 324 Rocket in it and barely cleared the steering box. I now have a sbc in it and it barely clears. There’s no question that the two bolt flange was brazed onto the sector shaft and probably came from a model a. It bolts in the same hole in the frame as a model a box. That appears to be fine. It steers well. I just need to know what it is so I can get a rebuild kit or have someone rebuild it. Thanks for your comments.
  16. Steve Cooper
    Steve Cooper
    By the way, the pitman arm is straight up. Had to build a Z bar from the pitman arm to step down to the wheel steering arm. I need a bearing that goes in the two hole flange( the one that’s brazed on) that mounts to the frame. The steering sector goes through that bearing. Thanks
  17. tomcat11
    tomcat11
  18. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
