Can Anyone on here make this bracket??
Discussion in 'The Hokey Ass Message Board' started by Toast, Feb 26, 2009.
  1. Toast
    Toast
    from Jenks, OK
    Here is a design I came up with for my headlight mounts on my current project. I need 2 of these cut out of 1/4" plate steel. I really don't have the tooling to make these. I'm not sure where to turn to to get these produced? I only need 2 so I am hoping it won't be real expensive:D. Anyone on here have any ideas??
  2. pinstripebob
    pinstripebob
    from Carmel, IN
    The high school I went to had a cnc plasma table that I used to cut some 1/4" brackets for my car a couple years ago. I'm friends with the shop guys there, I could probably swing in there and get those cut over my spring break, which starts March 13. Let me know if no one else can get those cut and I'll make sure you get them.
  3. Revhead
    Revhead
    from Dallas, TX
  4. V4F
    V4F
    from middle ca.
    i would think any GOOD speed shop could do that . actually , a plasma cutter & a drill press , you might try them yourself . if aluminum use a good jig saw . hand held grinders & files will clean them up .... just a thought ................ steve
  5. you should look for someone who could lazer cut it,or maybe water jet,for a sharp edge.... plasma kinda leaves a curved edge
    if i had to make it , it would be cut out in a bandsaw after first drilling the holes with drill bits and hole saws
  6. Stick004
    Stick004
    from Missouri
    Those guys just went in my favorites!! I'd be really cool to work there.
  7. Minewithnoshine
    Minewithnoshine
    We may able to laser them, I see the smallest hole is .250 which is the material thinkness which SHOULD be ok, I'll talk to a few guys and see what we can do.
  8. 40StudeDude
    40StudeDude
    PM Cadillaccoffin on here...(or e-mail him)
    I'm using him to laser some grille bars for my Caddy and he is damn good...and not terribly expensive... and he'll work with you...
    R-
  9. continentaljohn
    continentaljohn
    I'm taking the holes are just for looks and not functional, were a three place dec just adds to the price .000 + or - .005 were 2 place .00 would be + or - .015 for it to be produced just a FYI. If I were going to make them. Yep waterjet but $$$ lazer $$$ plazma $$ a bandsaw $ would be cost efficient. If you don't have a bandsaw a Jigsaw or sabersaw would do it. Drill the holes on a drill press or with a hand drill. Just drill the holes in a raw form when it in a square chunk. This way it's easy to hold and safer.
    A few guys will water cut goodies but have a minimum setup. You can get a sabersaw for the cost of the parts made and have a tool for life:D
  10. Toast
    Toast
    from Jenks, OK
    Thanks guys, Great info, If anyone can make it let me know? I thought I had someone doing it and they bailed on me and I am kind of needing it soon.
  11. Toast
    Toast
    from Jenks, OK
    Yes the holes are for looks to match other parts mounted close to these.
  12. Toast
    Toast
    from Jenks, OK
    I probably need them done on a water jet or laser to match the other parts on the truck.
  13. continentaljohn
    continentaljohn
    Just for ****s and grins what does such a part cost to have made? I ask because we do production parts ( 100 to millions) and the cost for one or two parts is in the set-up .
    thanks
  14. RichFox
    RichFox
    I would look into making those holes a standard size. Drilling a .500 hole is easy. .506 is extra work and money. .989 is only .011 smaller than a standard one inch or .005 larger than 63/64. same deal in time and money for the other holes.
  15. Toast
    Toast
    from Jenks, OK
    If the holes are slightly different it would be fine, Thanks
  16. butch27
    butch27
    Ron Pope In Tennessee. Good work and good prices. He's on here somewhere.
  17. charleyw
    charleyw
    Try laser specialties on New Sapulpa road. They've done stuff for my business. Ask for Gene Wood
  18. pacemaker
    pacemaker
    Austin Waterjet or the waterjet outfit in yer hometown. Cheaper than laser/cleaner than plasma
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i bet DW at welder series could make that for you..nice stuff they make..Hes a HAMBer and on here..welder series..vendor too. give him a call
  20. 51 MERC-CT
    51 MERC-CT
    Bandsaw and a drill press. Piece of cake:):D
  21. cadillacoffin
    cadillacoffin
    ill do it for 15 + shipping for a set of them and even make it out of grade 50
  22. I love technical prints, forgive me; but if these are just headlight stand...then I think the tech print is just a bit overkill....as to the fact you probly could've cut & drilled these out to your own liking within less time than it took to look up and place all the symbols in the print. Carl Hagan
  23. I think you need the outside radius and the centerline(s) for the radii.
  24. Toast
    Toast
    from Jenks, OK
    Got It Covered Guys! Thanks for all your help!!!
  25. Mr. Weld
    Mr. Weld
    I have 4 CNC mills and 6 CNC lathes at work and make parts like these for my home business all the time. I can profile and drill these in a snap and they will be perfect. Keep that in mind in the future.. You can drop me a e-mail if you have future needs..
  26. Toast
    Toast
    from Jenks, OK
    Ah.... Thanks guys but as it says 2 posts up I got it covered. I even have the brackets and installed them and started another thread on them since!
  27. 40StudeDude
    40StudeDude
    I think you'll find that a lot of people on this board tend to read the headline...and the first post, then immediately type their post before reading all the rest (besides, reading all the other posts is like way too much work...!!!) and they miss seeing the "I-got-it-done" post...
    R-
