Can front ends be hung like this?
Discussion in 'The Hokey Ass Message Board' started by Rpmrex, Dec 31, 2007.
  1. Rpmrex
    Rpmrex
    from Indiana
    I am wondering about the orentation of the spring and shackels. The shackels are down compaired to normal. Will it drive good this way?
    Sorry for the ****py pic.
  2. john56h
    john56h
    Can they....or should they?
  3. brewsir
    brewsir
    Thats some scary stuff...look at the scrub line....from that pic it looks like suspension hangin down way too far...even if it was above scrub I think having that spring hanging down like that would be something I wouldn't do.
  4. Dirty Dug
    Dirty Dug
    Your picture isn't clear enough to tell. What do you see as the problem?
  5. klemmy
    klemmy
    from Hobart,IN
    i have to agree with brewsir, it looks a bit low, its looks really close to the scrub line. ive seen them mounted behind the spring like this:[​IMG]
    but not usually on the wishbone like the pic u posted.
  6. Royalshifter
    Royalshifter
    Moderator
    Wow they are risking some serious "dip in the road spring hitting ground" problems at high speed.
  7. Rpmrex
    Rpmrex
    from Indiana
    Can they? is what I was wondering John56h I see it is real low but the shackels aren't pointing up,,,would it ride and drive ok that way if there wasn't a scrub line issue?
    Just courrious.
  8. Unkl Ian
    Unkl Ian
    Aside from the scrub line,the shackles are not a problem.
  9. 39 Ford
    39 Ford
    That is a front end to die from.
  10. tfeverfred
    tfeverfred
    That doesn't look too cool, man. You may want to rethink that setup.
  11. john56h
    john56h
    If there is no room for a spring...perhaps you should consider torsion bars ????
