Technical Can I cap off the 2nd inlet/outlet on a flathead radiator?
Discussion in 'The Hokey Ass Message Board' started by urbex, May 21, 2023.
  1. urbex
    urbex
    Just to clarify right away - I am NOT running this with a flathead motor...
    I have a '59 International medium duty truck with a blown radiator (leaks like a seive and is largely clogge) Yeah, I know... Not a hot rod, but I figure you guys would know this stuff that best. I have been searching for years for a replacement radiator, and can't find squat. Local places want over a grand to recore it, and that's way more than I want to spend on this thing since I haven't ever driven it more than moving it from one side of the yard to the other.
    I found a 42-52 Ford truck flathead radiator is close enough in size that I think I can easily make brackets to drop it in...but I don't need a pair of inlet/outlets on it.
    Can I just make up an appropriate sized plug on the lathe, and just do a super sized version of the old bolt in a hose trick to cap off the 2nd inlet/outlet that I don't need? If the truck drivetrain is good and I can fit the rad, I planned on having a rad shop replace both inlet/outlet to match the size/location of the factory radiator, I just don't want to invest that much up until I make sure the rest of the truck is OK.
  2. TagMan
    TagMan
    Mine is capped off on both an inlet & outlet and I've never had a problem.
  3. alanp561
    alanp561
    Why make a plug on the lathe? Local big box stores have enough plumbing parts to put together what you need. Two pieces same size OD PVC pipe with caps glued to them, short pieces of hose and 4 hose clamps and you're in business.
  4. Squablow
    Squablow
    The radiator will function fine, that was standard practice back in the day to swap most OHV engines into formerly Flathead powered cars. Most people then cut a piece of flat brass and cut the extra inlet and outlet off, and soldered the flat brass on over the top. But a plug system would work fine as long as it's water tight and heat/pressure proof.
    Robert J. Palmer likes this.
  5. squirrel
    It's so much more fun to make a plug on the lathe.....
  6. There was actually a rubber plug made just for that purpose. Not sure where you would find one today though. Maybe try ebay.
  7. urbex
    urbex
    Because it will take me less time and cost to turn a couple plugs than it would to drive to the store to buy things, and I can always use the material on something else later. Plus adding a retention bead is easy this way.
    I live pretty far out in a rural area, and the nearest hardware store is a 40 mile round trip.
    I figured this would be just fine, but there's been plenty of other times that something seemed to be a fine idea in my head, yet end up being a complete cluster in play, lol.
    Thanks all!
    302GMC, loudbang and TagMan like this.
  8. Pete Eastwood
    Pete Eastwood
    from california
    short piece of hose, a freeze plug & some hose clamps.
    31Apickup, loudbang and 40ragtopdown like this.
  9. deucemac
    deucemac
    OR, short piece of hose, two clamps, and a Gerber baby food bottle! Not only does it cap off the outlet, but you get to see what the coolant looks like !
    manyolcars and firstinsteele like this.
  10. 19Eddy30
    19Eddy30
    from VA
    Thin brass/copper preferred & Solder in
    Inlet / outlet , or a piece of tin,
    Easy to remove with hand / pocket torch later
  11. firstinsteele, Petejoe and Kiwi 4d like this.
  12. 19Fordy
    19Fordy
    PVC pipe will soften and deform from the heat and coolant temperature.
    At 198 degrees F PVC softens.
    olscrounger likes this.
  13. Nailhead Jason
    Nailhead Jason
    I used cast iron pipe plugs of the appropriate size to thread into the hose and then put a clamp on it, works great.
  14. manyolcars
    manyolcars
  15. dodge35
    dodge35
    from kentucky
    Had a built 301 in a 46 ford coupe in 1970. Soldered copper plates on the stock radiator and never had any problems.
