Can I Drill A Leaf Spring...??
Discussion in 'The Hokey Ass Message Board' started by Enbloc, Mar 8, 2007.
  1. Enbloc
    Enbloc
    from London, UK
    Is it realistic to be able to enlarge the centre hole in my leaf spring at home with a drill press and standard drill bits?
  2. 53sled
    53sled
    from KCMO
    make sure you have a high quality bit, go slow, you'l be ok.
  3. Soviet
    Soviet
  4. SUHRsc
    SUHRsc
    i drilled some springs right through all the leaves to make a 1/4 eliptic set-up
    drilled just fine for me
  5. hsheartaches
    hsheartaches
    Does a wild bear....nevermind. Yeah, you can do it. Lot's of 'cutting fluid' and some cobalt bits, and you'll be just fine. Why, per say, is this modification being made?
  6. Enbloc
    Enbloc
    from London, UK
    Its a long story but basically I have to use a rear Model 'A' spring bolt on the front spring. The rear spring bolt is bigger on the shank.
    Just drilled them all out and it worked fine. Thanks guys.
