Can it be done?
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Nov 25, 2004.
  1. fullhouse296
    fullhouse296
    from Australia
  2. dabirdguy
    dabirdguy
    I could see building a head using say 1/4" or 3/8" sheetmetal, layered one on top of another, effectively slicing the head in 1/4" or 3/8" increments.
    This would allow you to cut your p***ages with a torch or a hack saw if you wanted to.
    Sealing between the layers would be the only problem.
    Is there a process one could use where there was maybe a paste applied between layers and the pieces sandwiched under pressure and/or heat to seal or join them?
    Or Could the head bolts apply enough torque to seal?
  3. ENFO
    ENFO
    from Tucson AZ
    If it can be done..... MetalShapes can do it.
