Technical Can Most Any Steering Box Be Reversed?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 12, 2025.
  1. brigrat
    brigrat
    from Wa.St.
    Can Most Any Steering Box Be Reversed? Can I do it myself? If not Who can,
    Examples, '57 Chevy truck, '61 Vette, 525. Thanks!
    mad mikey likes this.
  2. Mr48chev
    The 50's truck boxes and 49/54 Car and 53/62 Corvette boxes are more mirrored rather than what we as hot rodders view as reversed. Not a flipped casting though as there are differences.
    The Fun part is that those car boxes can be moved to the right hand side frame rail and be run with a push pull drag link and be right hand steering.
    Reversing that other box would be just like reversing a Corvair box. Take the box apart, put the worm gear in the block from the other end and drill/machine a hole for a bearing and seal in the end cap and plug the old hole for the shaft.
    anthony myrick and brigrat like this.
  3. squirrel
    The way it gets reversed, is to turn the housing around, and have the shaft stick out the other end. So it won't work on the truck or car boxes that have the column as part of the housing. It would work on the other one, you have to drill a hole through the end plug, and make the shaft stick out the other end. But mounting the gearbox that way might prove challenging.
    This is a corvair box, and why it works so well with them
    corvair box reverse.jpg IMG_20171216_220331.jpg IMG_20171216_215057.jpg IMG_20171216_214113.jpg
  4. brigrat
    brigrat
    from Wa.St.
    Is a Corvair box to light for a '57 Blown, BBC, g***er type?
  5. squirrel
  6. Jmountainjr
    Jmountainjr
    The 525 box is easily reversed and suitable for your intended application. A lathe helps, but it can be done on a drill press if you work carefully. The critical step in the reversing process is flipping the gear on the worm gear 180 degrees to correctly position the tapered gear so the box can be correctly adjusted. If you search Reversing a 122/525 steering box there is a tech article about the process.
  7. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^^^^I have a Lathe, Thanks!^^^^^^^^^^^^^^^^^^^^^
  8. My Dad put a Corvair box in a small block 40 Chevy back in the 60's, it's still in there with no issues. He also put a reversed Corvair box in a small block 54 Chevy truck in the 70's. It was still in it without ever having a problem when it was sold around 2015.
    69fury and dana barlow like this.
  9. deathrowdave
    deathrowdave
    from NKy
    There were some big cube Mopar cars goin straight with aluminum steering boxes in the sixties . Don’t be afraid because it’s aluminum housing .
  10. gimpyshotrods
    gimpyshotrods
    I have done a few 525's.
    I'd use that, if that is already yours.
    lumpy 63 and squirrel like this.
  11. dumprat
    dumprat
    from b.c.
    69fury, brigrat and squirrel like this.
  12. squirrel
    The Corvair box isn't weak because of the aluminum housing, it's more to do with that everything about it is 2/3 the size of the front engine design GM steering gears. Smaller shafts, gears, etc.
    brigrat and 427 sleeper like this.
  13. gimpyshotrods
    gimpyshotrods
    Indeed.
    Going inside one reveals some really small parts!
    427 sleeper likes this.
  14. Jmountainjr
    Jmountainjr
  15. brigrat
    brigrat
    from Wa.St.
  16. brigrat
    brigrat
    from Wa.St.
    I am having a brain fart, can "reversing a steering box" mean 2 diff. things??? #1 being leaving the in & out in the same location & magickly changing things around on the inside? And #2 changing the in from one end to the other?
  17. squirrel
    To magically change things on the inside, you need to turn the right hand thread of the ball nut ***embly and shaft, into a left hand thread. Since that's pretty hard to do, we instead reverse the side that the ball nut contacts the pitman shaft, which means reversing the housing end to end, then having to deal with how the mounting of the gear is now reversed.
    There's nothing easy or magic about this.
    brigrat likes this.
  18. brigrat
    brigrat
    from Wa.St.
    Just a little dry humor Jim! I have thousands of dollars in "tools & machines" in the shop to try and make magic with!
    squirrel likes this.
  19. RodStRace
    RodStRace
    The point of reversing is to have it fit the application.
    The first question is, "is there a box that will do the job as-is?"
    Considering the vast amount of choices, this is your first step.
    Less work, easier to replace or repair.
    brigrat likes this.
  20. brigrat
    brigrat
    from Wa.St.
    ^^^^^^ Sound advice BUT if you grew up scrouging wrecking yards for parts they have all dried up in my area, hence the HAMB questions I post. I don't have time or money for " The wrong part or the Wrong way of doing things". I can't keep buying box's, like trying on shoes, to see best fit. This isn't reinviting the "wheel" been done over & over. The box is keeping me from moving forward in the rite direction. I can install the motor & trans & rear end faster than figuring out the front suspension!
    69fury and RodStRace like this.
  21. squirrel
    The trick I used on Plan II was to use the stock steering box in the stock location, and use a straight axle with cross steer. The axle was moved forward 4" which helps with clearance. The big issue is the drag link has to go through the oil pan. I lucked out and was able to use a normal Moroso 55-57 BBC oil pan, with the big notch in it that clears the steering. I don't know if this would work for you, but you might look into it. Header clearance near the stock steering gear is a ***** on 55-57 cars, and you also would have to deal with getting a steering arm that works. I used the street rod arm that Speedway sells for the 49-54 spindles.
    brigrat likes this.
  22. dana barlow
    dana barlow
    from Miami Fla.
    The simple A 2 Q,is there is always a way,,!, Just flip the streeing arm,from down to up=Now moves the other way*{ but often you need to move the box down in car,so you don't make too much bump steer.
    patsurf and brigrat like this.
  23. brigrat
    brigrat
    from Wa.St.
    Always appreciate everyone's detailed explanation! I like the look of nothing in front of the drilled axel so that's my first choice, second I am looking to build it like if it was in the '50's-'60's. The stock box won't work for me, I have a friend that has a '55 that used the stock box BUT he has a Speedway kit, Apple & Oranges! I am sitting high enough that the BBC pan is not an issue, in fact, latter I may go more " flattened Springs", dunno yet. Don't have stock truck steering arm yet to try out.
  24. nobby
    nobby
