Hot Rods Can someone help ID this Trans
Discussion in 'The Hokey Ass Message Board' started by 53kemper, Feb 10, 2023.
  1. 53kemper
    53kemper
    I'm trying to find info on this trans so I can get a rebuild kit. It was attached to my Flathead 8BA. 3 speed with serial number 41052. Searched and it could be a 39-40 and possibly out of a Merc but this engine and trans came out of a truck.
  2. WiredSpider
    WiredSpider
    My crystal ball isn’t working so some photos would help
    53kemper likes this.
  3. 53kemper
    53kemper
    Sorry was having an upload issue.
    VANDENPLAS likes this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Early '50s Ford pickup. Handy for bolting to an early flathead, but being able to run an open drive rear end.
    gary macdonald and hrm2k like this.
  5. deucemac
    deucemac
    48-52 F pickup 3 speed with open drive output shaft and rear mount. Same basic trans used in 40-48 p***enger cars with closed drive output shaft and mount.
    hrm2k and rusty valley like this.
  6. 53kemper
    53kemper
    I'm building a belly tank with a 38 wide five bajo rear end. Was thinking about running the bajo and trans with this speedway adapter
    Deuces and 26 T Ford RPU like this.
  7. 53kemper
    53kemper
    Only kits I can find are for 39 -48
  8. deucemac
    deucemac
    I need to correct myself. This open drive was actually used from 42-52 in pick up trucks.
    Desoto291Hemi likes this.
  9. dwollam
    dwollam
    I have one just like it. Pickup trans as said above.
    Dave
  10. Looks kind of like former my brother Charlie who went that route and is now my "sister" Charlene, but I might be wrong.
    Oh. you meant TRANSMISSION! "Trans, ******, dizzy..." Doesn't anyone know the real names of stuff?
    SS327 and VANDENPLAS like this.
  11. 53kemper
    53kemper
    Anyone know a place to source a 16spine yoke for this trans?
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I believe that 1955-63 Chevrolet yokes will fit.
    Andy likes this.
  13. Hitchhiker
    Hitchhiker
    Have you tried Van Pelt?
  14. The yoke fits all Powerglide GM cars. If you actually do a Belly Tank project staying closed drive makes everything much easier as for Fab work.
  15. Mac VP
    Mac VP
    The late 60’s Powerglide yoke will fit the 16 spline output shaft of the open drive Ford transmission he has. However, it must be shortened by about 1.6” and then rechamfered. If you don’t do this, the yoke will not have correct engagement of the splines on the mainshaft. Left unmodified, you’ll either have too much slip yoke hanging outside the transmission, or you’ll find that the front of the yoke will bang into the speedometer gear snap ring with every bump in the road.
    Pist-n-Broke likes this.
  16. This is the rest of the story as Paul Harvy used to say. I have a ratted out old one that hangs on the wall behind my Layth for a Polish blueprint.
