Can someone ID this speedometer?
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Dec 8, 2011.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    Im gonna run this in my speedster. Bought it off ebay a while back, CHEAP. I'm just curious to what it came from. Eventually I will need to know so I can buy a speedo cable.
    Thanks
  2. hillbilly4008
    hillbilly4008
    from Rome NY
  3. adamshumard
    adamshumard
    Its not just Stewart Warner aftermarket?
  4. Jonnie King
    Jonnie King
    from St. Louis
    I agree...could be a generic. Unless someone else has a better insight to it.
    Jonnie King www.legends.thewwbc.net
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    I doubt a generic speedo would have the fancy bead on the bezel. It is the style of the 28-31 Ford As with the rotating barrel for speed, a mileage meter and a tripmeter. So the era would be pre-32 and likely a bigger car than a Ford. Now comes the search for the dash with a uniquely beaded rim speedo.
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    bump for the morning crew
  7. dana barlow
    dana barlow
    from Miami Fla.
    Window open shape makes me think of AF fire engine dash:cool:
  8. Adrian Rollini
    Adrian Rollini
    It looks like an after market 20s-30s speedometer.
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    So should a standard speedo cable work?
  10. tommy
    tommy
    It came on some fancy car from the middle 20s into the 30s. I've never seen a universal speedo with a trip meter and the reset knob. There were so many makes back then that it may be hard to find exactly what it came in. It could be a "Sterns Knight" for all I know.
  11. dirt t
    dirt t
    I would agree middle 20's -30's
  12. The37Kid
    The37Kid
    Has a Buick look to it, mid to late teens. Bob
  13. What # are on the Back.?
    and if you need a Cable NAPA wood be the Place to
    go, just have to match the Treads & Size & how long you
    want it
    just my 3.5 cents
  14. Mopar Jack
    Mopar Jack
    Whatever its for, its cool....
  15. Slick Willy
    Slick Willy
    1928 Buick, I think the dash panel had its own chrome bezel that went up behind
  16. patrick66
    patrick66
    I'm thinking '27 Hudson or Es***, but I am not positive.
  17. MORRISGAUGE
    MORRISGAUGE
    The case or face part numbers would be of ***istance. It does not receive a "standard" speedometer cable. I wouldn't hook it up until it has been serviced. That unit may have a phenolic fiber first worm gear that needs proper lubrication. Also, the pot-metal frames tend to expand/contract/shift/break over the years. If things are out of alignment or seized, it will ruin itself or the cable in short order.
  18. hillbilly4008
    hillbilly4008
    from Rome NY
    I'll get the #'s next time I'm in the shop.
    I doubt that anything is seized inside the gauge. I can flick the gauge with my wrist and get the speedo to roll pretty easily. The roller goes so fast I still don't know what top recorded speed is. I think I saw 80.
  19. MORRISGAUGE
    MORRISGAUGE
    Shaking the case or turning the magnet shaft at the cable interface?
  20. hillbilly4008
    hillbilly4008
    from Rome NY
    shaking the case. I can spin the shaft easily with my finger tips, but am not able to spin it fast enough to register anything.
  21. pug man
    pug man
    from louisiana
    I have no idea what it comes from but I like it!
  22. MORRISGAUGE
    MORRISGAUGE
    The magnet shaft free rotation is the better indicator. The speedcup movement simply means that it, as a sub-***embly, is unobstructed.
  23. stude54ht
    stude54ht
    from Spokane WA
    This is close, 1928 Buick
