Technical Can someone please do a tech thread on refinishing stainless trim?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Aug 16, 2021.
  1. Roothawg
    Roothawg
    I understand the basics, but I would like to see a step by step process on repairing dented or creased stainless. Specifically the polishing portion.
    What compounds are more aggressive or finer etc. The steps you take to get that mirror finish. Any tricks or things a guy has learned through hard knocks.
    Also, I would be interested in how to finish off a piece that has to be shortened. I have heard old time customizers talking about folding the ends over and silver soldering the joints. I have never attempted it and i will need to in the distant future.
    slim38 and Dos Cincos like this.
  2. 57 HEAP
    57 HEAP
    rpm56, egads and Roothawg like this.
  3. egads
    egads
  4. Roothawg
    Roothawg
  5. A Boner
    A Boner
    Start off soft and gentle...use some s****s of aluminum to make special shaped tools...think they are called (corking tools) to aid in tight spaces that the hammer doesn’t fit in.
    Start with very fine wet sandpaper or polishing compound. If things are not progressing, or hardly progressing go slightly co****r. Repeat as necessary. If you start co****, you might put some deep scratches that will take lots of work and time to remove. Use a s**** piece to test on!
    I would tig instead of silver solder.
    Roothawg likes this.
  6. Roothawg
    Roothawg
    I’ll be ordering the book for sure.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Root, there are some good tips in this old thread. HRP
    STAINLESS
  8. Bandit Billy
    Bandit Billy
    I always have a few of these kits in my cupboard (rather than spark plug wires).
    They will take you down to a nearly perfect surface that doesnt need a lot of time on the buffer.
    As far as straightening, there was an excellent thread a while back that showed cutting a dado in a piece of hardwood to use to buck against and soft blow tools to hammer and pick the dents out. I have saved a lot of trim since reading that thread.
    egads and Moriarity like this.
  9. Roothawg
    Roothawg
    You have a link Mr Billy?
  10. Mattimus
    Mattimus
    Bandit Billy likes this.
  11. 325w
    325w
    Be real careful polishing the headlight retainer rims. You’ll run one of those sharp little Jews up your arm to the shoulder.
  12. Roothawg
    Roothawg
    Sorry. I meant about the thread he referenced, but thanks for the link anyway.
  13. RICH B
    RICH B
    Use your drill press and a shaped wood dowel to press out dings instead of hammering on them. One of those mini anvils is handy; but polish the surface and relieve the corners first; same goes for your dinging hammer; you don't want to add extra tool marks. Taping moldings to a piece of wood when buffing; saves damaging both the trim and yourself. The wood pieces can also be cut to the shape of curved trim. Shaped blocks are handy for light bezels. Careful not get the metal too thin by overly aggressive sanding. One of those steady handed wizards that can work magic with a tig is handy for gouges and shortening; use a piece of the same trim for filler to get the same color to the weld. Patience is one of the most important skills needed.
    X38 likes this.
