Technical Can someone school me on this flathead?
Discussion in 'Traditional Hot Rods' started by Willy_P, Feb 10, 2014.
  1. Willy_P
    Willy_P
    I know very little about flatheads, but if I had one, it would sound like this!
    Killer lope...
    Can anyone comment on it - perhaps who the builder is, and the component list posted with the video?
    I think I have played it about 100 times - I guess it reminds me a lot of the john deere tractors we drove on the farm.
    First Start Up And Run of C69A, 276 cube, Egge 3-5/16 pistons, 53 Merc 4" crank, 8BA Isky Max 1 cam, 8BA Rods, Johnson Hollow Adjustables, LZ Valve springs, 1.5 Proflow stainless valves, Hardened valve seats, M19 Oil pump, 8BA Mallory Twin Point conversion to Pertronix, Bob Drake bearinged 8BA water pumps, Offenhauser400 heads and Offenhauser Dual Intake, Dual 97's, Lightened 46 flywheel, balanced with 10 inch clutch.
  2. Bruce Lancaster
    Bruce Lancaster
    Well, a clue on the origin of the build: C69A is a Canadian designation, so likely the build took place in Canada, Australia, or somewhere else in the old Empire.
    Cam is probably main component for the sound.
  3. harleyjohn45
    harleyjohn45
    A stock flathead with a 3 foot open exhaust will lope, cam or not. I have a 53 ford pick up motor that is entirely stock with the same sound. Its just their nature.
  4. Bruce Lancaster
    Bruce Lancaster
    Have you ever started a flathead with no exhaust manifolds at all??
    Holy$#$##$!!!!
  5. primerhotrod
    primerhotrod
    from ILLINOIS
    HAHAHA I'm thinking he hasn't.
  6. Willy_P
    Willy_P
    You are right, I have not heard one with no manifolds. But I did both of these jobs in the 60's when I was a teenager, 10 hours a day in the summer - JD G wide track and model 70. That sound and the warm exhaust would almost lull you to sleep after a while.
    I think I would rather build a flatty, even if it just sat on the stand for a while until I find the right home for it maybe a 27 roadster similar to the one in the ****gy dog movie. Better finish the 57 chebby first;)
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Yep. Those are loud sob's.
    Always said a flatty sounds like a cross between a JD and a Harley.
    Coolest sounds of all. Power or not.
  8. Bruce Lancaster
    Bruce Lancaster
    No manifolds does not compare to ANY other configuration...I suspect it is rather like being attacked by an airplane with 8 fifty calibers, but fortunately I can't say for sure about that.
    I did it when I had an engine installation in my '48 nearly finished, and figured I could get in 30 seconds of hotroddish unmuffled sound and then shutdown before neighbors woke up enough to get a fix on me and call the gestapo.
    WRONG. It was NOTHING like a car with no muffler or a car with just manifolds... the staccato and the unmixed blasts made it MUCH louder and more violent than that. I nearly broke a leg leaping into there and shutting it down, then I slammed the alley door and fled into the night.
  9. 38 coupe
    38 coupe
    from Texas
    Bruce, how does a flathead with no manifolds compare to a dragster flathead with zoomies?
  10. Garagekulture13
    Garagekulture13
    I had no idea they were that loud without exhaust. That's a great sound that every hotrodder wants. Great story. LMAO
  11. Bruce Lancaster
    Bruce Lancaster
    No manifold sound is distinctive because of sheer violence, I think...exhaust pulses are not mixed with others (at idle, as I started the thing, I'm guessing that the center pulses were far enough apart to emerge individually, as the racket was very even), they just emerge with a sound like a gunshot distinct for each. Rather like a Browning 50, in fact. Dragsters have always seemed quieter to me...maybe the short pipes somehow make the liberation of the charge tune down a bit, and of course there is more RPM than an idling stocker so there is no audible space between explosions and the can so merge and kill the staccato.
    I have no idea why the emerging pulses were so violent on the stocker, as of course they would seem to be cooled and muffled a bit coming through the block. The reality was much like muzzle blast.
    I never had a chance to explore the phenomenon...I was in an alley between two rows of houses at midnight, one block from Police HQ, so the only sane response was to shut down, slam the door, and disappear into the night. I would have loved to rev the thing up, though!
    Anybody on here have a garage 17 miles outside of Resume Speed, North Dakota and a desire to experiment??
  12. Doctor Detroit
    Doctor Detroit
  13. Bruce Lancaster
    Bruce Lancaster
    Breathing fire good!!
  14. the-rodster
    the-rodster
    Hasn't everyone?
  15. Willy_P
    Willy_P
    Bruce, that is a funny story right there.
    Flatty that is the sound every hotrodder wants.
    Doc, that is a sanitary build you are doing. Looks killer and flames to boot!
  16. cabong
    cabong
    Idle schmidle............You haven't lived until you've run the straight at Laguna Seca at 110mph/5,500rpm in a 950 pound Crosley with a flathead V8-60. That, my friends makes the adrenalin squirt from the ears!!!!!! Lightweight midget headers, '36 Ford inner driveshaft tubes, 3-81's staring you in the face, it just doesn't get better than that!!!!!
  17. primerhotrod
    primerhotrod
    from ILLINOIS
    That image is pure heaven.
  18. primerhotrod
    primerhotrod
    from ILLINOIS
    Running any engine with no headers/manifolds has a distinct sound. I recommend every one witnesses it once in their life. Start an engine on a cherry picker, and tap the throttle a few times, that will freak all your buddies out.
    It is not recommended to do it for more than a very short period. It will hurt the exhaust valves. Some sort of manifold/header is needed to absorb the exhaust pulse.
