Can someone tell me what motor this is?
Discussion in 'The Hokey Ass Message Board' started by VINNIE JAMES, Jan 30, 2012.
  1. onedge
    onedge
    Hope it works out for you that do just fine in that 52.
  2. VINNIE JAMES
    VINNIE JAMES
    i did not know what con8 was? or if it meant anything? size? or hp?
    from what i read I think i have to change the water pump? and not sure about anything where the trans bolts up? i still need to see if it runs...thanks, vinnie
  3. VINNIE JAMES
    VINNIE JAMES
    squirrel...may 1st 1958. is that good? or bad? lol
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's good that it's a '58 block, as it will have mount bosses in the same location as the stock '52 block does, although the pattern will be different. A simple pair of homemade adapter plates welded to the stock mounts will take care of that problem. '55-'57 235s don't have any side mount provisions there.
  5. GREASER815
    GREASER815
    BUY IT! Full pressure 235, great engine. Just use your original bellhousing, flywheel, starter, your done.
  6. GREASER815
    GREASER815
    Forgot, I am putting a 60 235 in my 50 Chevy. Go on Ebay and for $40 you can buy a water pump adapter plate and use your original water pump. Plus it mounts it back in stock location to center the fan in your radiator.
  7. VINNIE JAMES
    VINNIE JAMES
    cool. thanks again...ill let you know if it starts
  8. VINNIE JAMES
    VINNIE JAMES
    does the dual groved crank pulley make a difference?
  9. squirrel
    ??? looks to me like only one belt groove. There is a gap between the front part of the damper, and the belt groove part, but the gap is not for a belt.
    Unless I'm looking at the picture wrong.
