Can somone indentify this sbc?
Discussion in 'The Hokey Ass Message Board' started by Gasolinedeniz, Mar 27, 2013.
  1. i have to know what kind of engine i have, well it is a sbc but anybody know what year? output and so on ? found only this numbers on it
  2. 38standard
    38standard
    from il.
    64-67 327 2 bolt main
  3. dragsled
    dragsled
    from Panama IA
  4. Edd
    Edd
    '62-67 327 & 327 Corvette
    What are the stamped numbers (Suffix codes) on the flat pad surface, p***enger side front where the head meets the block.
    Pull a valve cover for the casting numbers to see if those fuelie heads are large or small valves.
  5. pdunn10
    pdunn10
    edd and 38 standard are right
  6. pdunn10
    pdunn10
  7. CW's40TPU
    CW's40TPU
    dragsled......THANKS for casting info.
  8. dragsled
    dragsled
    from Panama IA
    No Problem , I found it on the net when I was trying to Id a block I had, Glad I saved the link ,,, Tim Jones
  9. Black Panther
    Black Panther
    from SoCal
    1965 327 to be precise cast November 24th of 1964 for 1965 production....all 327s back then were good...275 horse on up depending on whats on the front stamped pad...
  10. black 62
    black 62
    from arkansas
    327's are good...
  11. thanks a lot ,i have to search the other numers, did not see em because the paint over it :) have to clean and overhaul it a bit anyway. Tank you
  12. LowKat
    LowKat
    cast on 11/24/1964 (for 1965 production) 327 (great engine)
    300HP and up with the 'double hump' heads
    as others said post your suffix code off of the front stamp pad.
  13. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    ^^ As mentioned above^^ K244 is Nov. 24 64 so it would be a 1965 production motor, only small blocks made then was 327 and 283. Check your pad stamping or casting numbers for cubic inch and car/truck it would have been installed in. The valve covers are new.
  14. LowKat
    LowKat
    an '870' block is a 327. It also has the large font casting number making it a Flint MI casting and possibly Corvette, (all vette enginges were Flint castings and not Tonowanda NY)
  15. thanks so much, sadly it needs a rebuild took it apart last sunday and had some rust in the cylinders:-(
  16. F-ONE
    F-ONE
    from Alabama
    How bad is the rust?
    You would be surprised at how well rusty cylinders clean up with just a little elbow grease.
