Can This Volksrod Thread be revived?
Discussion in 'Off Topic Hot Rods & Customs' started by A Boner, May 13, 2024.
  1. A Boner
    A Boner
  2. A Boner
    A Boner
    Sleeze by Billy Belmont.
  3. goldmountain
    goldmountain
    I think it would be interesting to build a T bucket with a small engine in front with the dimensions of a volksrod and a louvered pickup box to fool old guys who remember these cars.
  4. Ned Ludd
    Ned Ludd
    Sounds like a job for a 13B!
    chryslerfan55, mitch 36 and AHotRod like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Most of the ones I remember seeing had that weird rear axle placement that made the back of the car look heavy. Somebody did one as a truck, can’t remember now if it was a van or stakebody, but they shortened the engine by running the exhaust forward and out in front of the tires, and they also extended the nose a bit to balance the side view.
  6. AHotRod
    AHotRod
  7. A Boner
    A Boner
    Definitely could use some different wheels and tires! ECC24A7A-22A8-46E7-B499-740AB6E367D2.png
    F33E967D-48E7-410A-BE1A-427918DB941A.png 10DE2D63-3828-464F-9D4C-A70E62BA7F00.png
  8. A Boner
    A Boner
    Apparently not, but I’ll try to keep it on life support!
  9. A Boner
    A Boner
  10. A Boner
    A Boner
  11. nrgwizard
    nrgwizard
    from Minn. uSA
    Yellow one is(was owned) by Walt Leatherman, I believe he's p***ed, sadly. He was quite the machinist. He n his kid built a handful of acvw/'vair powered rods, incl a 'vair powered chopped/channeled '34PU. The Yellow T was one of the few VolksRods built by Kent Fuller. Walt found it in disrepair, & redid it, had a website(now gone) showing the progress, the blower is(iirc) a **** Landy mini(gmc-style) & seriously woke up the little acvw mill. The T got featured in StreetScene, maybe one other rodding mag.
    Marcus...
    chryslerfan55 and down-the-road like this.
  12. A Boner
    A Boner
    Yep, the yellow one has great proportions!
  13. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, A *****;
    Don't remember the red flamed one. Might be a V-23 from Speedway, which was Fullers' old patterns/jigs. Otherwise it's a real close copy of Fullers' ch***is(at least from the rad-shell -> near-back-of-body. Other than wheel/tires, all that thing needs is an appropriate-length bed, or a turtledeck, maybe lose the rollbar. Proportions aren't all that bad on that one. Got anymore pics/info?
    TIA.
    Marcus...
  14. pprather
    pprather
  15. A Boner
    A Boner
    Good old Rod & Custom Magazine!
    07928BAA-D33B-4333-95BF-DCAEC7E5FDC8.jpeg 774E57A8-063C-43EA-8690-14FCA53F1058.jpeg EA451049-D8DA-4B2F-B7CE-62135CC038E1.jpeg 2BEA555E-9914-4DFA-9D06-2955317DB649.jpeg 96F02F83-AD0C-40EC-B53F-13E80C289DFD.jpeg
  16. A Boner
    A Boner
  17. duecesteve
    duecesteve
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    That looks su****iously like Speedways' VX23T ad.
    Marcus...
    chryslerfan55 and porkshop like this.
  19. A Boner
    A Boner
    Yep…looks sort of familiar.
    Wonder if the jigs/stuff for the “kit” are still in a Speedway Motors Warehouse?
  20. A Boner
    A Boner
    Or is this a Speedway Motors Kit?
    chryslerfan55 and Gasser 57 like this.
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    The headlight bars looks like Brizio InstantT.
    W/o seeing the frame, & maybe the flooring, it's kinda hard to tell. I'd guess not-Speedway/VX23T.
    Marcus...
  22. A Boner
    A Boner
  23. nrgwizard
    nrgwizard
    from Minn. uSA
    That straight-railed t****zoidal ch***is was done by(iirc) Tex Smith & Tom Medley, looks very similar to the plans in ~'67 R&C. Which was copied - by prior agreement - by Dode Martin for his VolksRod ch***is/kits. Plans gave a few options, none of it rocket-science.
    AFAIK, Brizio used Dodes' ch***is, or at least the layout from R&C. Fuller(& therefore Speedway) ch***is followed the body nicely. Looked better, & gave more room 'twixt the 'rails for a dropped floor.
    But there were quite a few homebuilt - well, at least started, anyways...
    Marcus...
  24. A Boner
    A Boner
    Always liked this example from the U.K.!
  25. Phillips
    Phillips
    This one is turning out nicely
  26. nrgwizard
    nrgwizard
    from Minn. uSA
    Any pics of the frame from underneath or a body-off shot?
    Know who the builder was?
    Marcus...
  27. Phillips
    Phillips
    I did borrow a frame pic - it's from a Scott on an "unfinished hot rods" FB group that I cannot seem to find now. (edit, looks like A ***** posted the same frame from a different angle above)
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    That's the R&C-style V-Rod ch***is in the plans. See post #15 & #23.
    Still nice looking ch***is & V-Rod.
    Marcus...
  29. oldiron 440
    oldiron 440
    I can’t say I ever knew about VW rods, they look like fun.
  30. nrgwizard
    nrgwizard
    from Minn. uSA
    1st showed up in R&C, June '67.
    Straight t****zoidal frame has pros n cons, as does Fullers' body-contour-following frame. The straight frame is easier to build, but you lose ~ 6" footroom on both insides of body, if as usual, body is channeled, & floor is dropped 'twixt the rails, so you gain depth, but still lose the width. The curved rails are harder to do as they need to be carefully bent to a pattern & when channeled only lose about the dia of the rails. So you can gain both depth & lose very little width. In this case, if using recommended chrome-moly, ~ 1.5"(+ floorboard thickness). Mine will be done the hard way. :D .
    Hard to build heavy, biggest "issue" is very light front end. Wheelie-city if not careful. Even w/a screamin' single-port 40hp stocker. Some guys used the Type IV(read: expensive, but near-bullet-proof if done correctly), some even used the 'Vair mill/transaxle. As usual, I'm planning a hard(er) version, a "Type V" concoction. May as well run turbos, w/efi, et-al. Not sure what to do for heads anymore, since a 4" bore is planned. Major sticking point right now. Phooey...
    Bo Bertillison(sp?) had probably one of the nicest. The Instant-T V-rod for Andy Brizios' wife was also really nice. Walt Leathermans' is also very well done(rebuild of a mess). & a few others featured in various mags. But I don't think you could have more fun in anything else. Unless it's maybe a 427 Cobra or a DOHC-Indy-engined GT40. & that'd be only in the mid->top end.
    Best part is that women n kids love 'em, on the other hand; streetrodders/hotrodders hate 'em 'cause it's got a vee-wee mill, & the Volks-folks hate 'em 'cause it's got a "ford"(read: *not* vw) body. What else in the world can you do to have so much fun in, fairly cheaply, get a permanent smile, & still piss-off so many other people w/o even trying... :D . & then point out that some of the "names" of streetrod industry had them as personal cars? Last I heard, Kent Fuller still has his, drives it alot.(Paint is white now). The man who built record-setting rails n funnies, over what - 50+yrs(?), keeps his V-Rod which he had before 1967. Gotta say n mean something... :D .
    Marcus...
