Can we build a hot rod in 3 weeks?..........
Discussion in 'The Hokey Ass Message Board' started by redbeard, May 19, 2005.
  1. redbeard
    redbeard
    this is what we are starting with
  2. redbeard
    redbeard
    here is the motor mocked up, free small block boat motor because it was in
    a freeze. cracked the side of the block.
  3. redbeard
    redbeard
    We wanted to raise the motor up so we made so risers out of 2x4 steel
    which also are the motor mounts.
    we did not make this frame, Neil got it with the body for a hundred bucks.
    since we are in a hurry we are not going to change anything on it.
    Just get it on the road and driving.
    end of day one.............. motor mounts welded on and wishbones mounted to frame, front and rear mocked up with body.
  4. 52pickup
    52pickup
    from Tucson, Az
    I think its possible. i was going to try for 4 weeks myself, but then came to realize none of my friends are any good at fab work, and im not in a club so looks like the goal will be 3 months instead.
    good luck, and keep us posted
  5. crapshoot
    crapshoot
    three weeks oh hell ya you can do it looks like your already off to a good start
  6. redbeard
    redbeard
    day two
    we made our own brackets to hang spring so it would fit frame.
    we cut the tubes off of 46 front bones to hang the shackles
    then we welded in the perches to the wishbones. these are 37-41.
    we actually split each bone along its length and welded in 5/16" plate
    running top to bottom for about 10" of length, right where the perch goes
    through. so it is welded on both sides and running through a 5/16 plate.
  7. redbeard
    redbeard
    still day two
    here is that 46 front wishbone, we are going to use it for the rear unsplit
    here is the ****** mount. the wishbone will mount on the front
    side of it and the ****** mount is on the rear of the tube.
  8. Three weeks? ****, Marshall here on the HAMB did one in nine days, or something like that.
    You can do it.
  9. redbeard
    redbeard
    I have not take pics every day so here is day five
    mounted front shocks
    we also weled gussets to the ******/ wishbone mount
    mounted the doors and mounted the front spring
    here is end of day 5
  10. redbeard
    redbeard
    Thanks for the encouragement guys, we are doing this after work on nights and weekends. there are four of us trying to get this car to paso.
    we mounted the steering box based on an idea that C9 discussed here on the
    hamb.
    we took a flat head connecting rod and cut off just the bearing end.
    we are using a steering box from a 59 volvo, donated, so we ground the
    flanges off the box so it fits in the connecting rod. then c notched frame
    and welded one half of the connecting rod in as the c notch boxing
    then set the steering box into notch and bolt down cap. we are welding
    the cap to the box so it cannot move. all in all it worked out pretty good.
    we also shortend the pitman arm as much as we dared. it ended up a little
    stiff since the steering box only has three turns total, so turn fast but with
    more effort.
  11. redbeard
    redbeard
    here is a pretty good trick for dressing up a steering column.
    we used a ford truck column tube over the volvo steering shaft. we cut off the big bell normally on the end
    then we used the bell off of an air horn from a boat.
    a little grinding and fitting
    and you have a stock looking column for a bell wheel
  12. PrimeEvil'36
    PrimeEvil'36
    that colum idea is awesome,i'm gonna have to jot that one down ,great way to be resourceful......
  13. redbeard
    redbeard
    here is a better pic of the ******/wishbone mount
    we made our own brackets to mount the wishbones to the rear end, I don't have very good pics but here is when it was tacked in place.
    I am aware some of you may not like this style of mounting a rear solid.
    but I read alot of info on the hamb as well as talked to alot of older
    race car builders and drivers. if it breaks I'll let you know.
  14. redbeard
    redbeard
    this is day 8
    we are using lever shocks on the rear
    so we welded tabs on the rear and used clevises and threaded rod to tie them together, this is a bad pic
    we also used another connecting rod cap to mount the column to the dash
    and we adapted 57 ford pickup pedals to fit the 60 chevy dual master, the
    fire wall was already bored and I had the pedals, we also bent the pedals and
    turned the pads from horizontal to verticle to hang down more.
  15. redbeard
    redbeard
    man I hope my photo bucket works
    here is day 9
    rear end is in and tank is mounted and drive shaft is in
  16. redbeard
    redbeard
    we are putting zoomies on this thing, because we are cheap and they are
    fast. so here is the baffles we are putting in.
    your looking at the end which is further in the pipe, it has a 1/8" hole in it
    and 3/8" holes down the side
    then we put a bigger fender washed on the other end which has a 5/8" hole
    and fits in the 1 3/4" zoomie.
    i would grind off the coating next time, nicer to weld and breathe.
    we cut the flanges off some fenderwell headers to use
    we also got the motor plumbed and the headlights mounted and radiator and shell mounted
  17. redbeard
    redbeard
    neils daughter came over to help bleed the brakes while we built the zoomies
    Kind of funny she never wanted to help on his buick but she is into the hotrod
    here is the end of day 17
    what do you think are we gonna make it? hahaha
  18. PrimeEvil'36
    PrimeEvil'36
    she looks like a pretty cool chick,haha.....
    i'd put a few dollars on ya makin' it;) ....
    damn,impressive,man....
  19. redbeard
    redbeard
    here is motor with plug wires and generator and valve covers
    steering is hooked up
    here is the dash and shifter hooked up to chevy 3 speed manual
    got to love those bus seats we got for free
  20. redbeard
    redbeard
    here is the end of day19
    just need to finish wiring and fill her up and fire it.
    maybe tommorow we will get it running.
    see ya then.
  21. Jive-Bomber
    Jive-Bomber
    MODERATOR
    SANTA ROSA DOPE SMOKERS!!!!
    That things looking good... Shake it down before Paso, eh??
  22. ChuckleHead_Al
    ChuckleHead_Al
    Cool build.. This is getting better..
  23. Levis Classic
    Levis Classic
    There is some great work there guys. That column bell it an amazing idea.
    Best post I have seen in a while!!
    Keep us posted
  24. Petejoe
    Petejoe
    from Zoar, Ohio
    Wow, Great work. Now thats what hotrodding and building is all about.
    And to think we have been farting around with a traditional T for three months.
    And we still have work to do.
  25. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    I'm going to try to build one in about 10 days, starting Monday!!! :eek:
    (Any GMB's that are up for late night thrashes, PM me!!!;) )
  26. RocketDaemon
    RocketDaemon
    from Sweden
    that pitbull looks just like my ol pitbull (rip) ohhhh
  27. flatheadpete
    flatheadpete
    from Burton, MI
    I've seen it done on TV so anyone can do it.
  28. Yo Baby
    Yo Baby
    :cool: What a bunch of animals and takin' time out for pics.
    HOOOOWAHHHHH,I love it.
    T.OUT
  29. kisam
    kisam
    Hey Dad-Your going to ruin your daughter! Just like mine did me-I was about that age when my Dad bought me my first car-49 Ford Pickup-He showed my how to shift and turned me loose in a field. Fast forward 30 years and last night I was asking my 79 year old father if he would teach me how to lead on my next trip home to Missouri! Sure do love him!
  30. Fat Hack
    Fat Hack
    from Detroit
    Way to go!!!
    Dedicated and determined rodders can get LOTS done in a short amount of time! DirtyT took his car from a gutted hulk surrounded by parts to a running, driving vehicle in about three weeks, and it looks like you're gonna make it, too!!!
    (Now, we just gotta get Steve's 34 built in the next TWO weeks!!!:eek: :cool: )
