Can we build a hot rod in 3 weeks?..........
Discussion in 'The Hokey Ass Message Board' started by redbeard, May 19, 2005.
  1. JOECOOL
    JOECOOL
    Remember Boyd says you must Box the frame.!!!
    I can't even get the wiring done in three weeks,go figure.
  2. Django
    Django
    from Chicago
    inspirational...
    I'm unclear on the motor... it has a cracked block??
  3. redbeard
    redbeard
    Hahaha, we actually made Neil stop smoking weed for the build, he has alot
    more energy now and can almost remember what he is supposed to get done
    each day.
    Django, you must have jinxed us,
    the motor is a boat motor with about 40 hours on it, like I said it was in a freeze and the block cracked on the side below the exhaust. it is a crack
    in the water jacket. It has been welded up before we got it but it is a big
    worry for us, but it is so clean and fresh inside and it was free.
    well we filled up the radiator this morning in preperation for firing later and there are tiny droplets forming where the crack is, this really ****s because
    there isn't even pressure yet or heat.
    we do have access to other motors but we really didn't want to swap out the motor this close to go time. It was a gamble I guess we lost.
    the guy who gave us the block is convinced some block sealer and maybe
    JB weld will fix it.
    so we are putting in the block sealer and we will see how it acts later today.
    it runs pretty good(you have to run it for 20 min. for the block sealer)
    it is not streaming out at the crack, just tiny droplets every 10 seconds.
    thanks for all the encouragement, this is definately the low point after working so hard.
  4. singledownloop
    singledownloop
    as much as you guys have done in this short of time that block problem will just be a blip on the screen,good to see people getting things done.I would've had that much time in thinking about it.
  5. lizzard05
    lizzard05
    from CALIFORNIA
    that's one bad *** rod ! ! ! ! !:)
  6. Django
    Django
    from Chicago
    aw ****, that ****s! :(
  7. redbeard
    redbeard
    Ok after the 20 min running the motor we drained out the block sealer and we have to let it dry.
    the good news is the block stopped leaking, at least for now.
    the motor ran ok, but one of the carbs is not working.
    so we will have to rebuild that. motor has 45lbs of oil pressure
    and came up to 180 deg and stayed there for the run in.
    bad news is the radiator leaks and it did not stop, so we need another
    radiator and make new mounts.
    and rebuild the "rebuilt" carb.
    gotta go to work
  8. coupeHEAD
    coupeHEAD
    Good job! Lots of cool tricks. Hope you guys get it to Paso. Thanks for posting.
  9. Fat Hack
    Fat Hack
    from Detroit
    Just run a very low (like 4-7psi) radiator cap and maybe a little more block sealer...keep an eye on it, and hope for the best.
    ...carry a couple jugs of coolant with ya, too!
  10. ****ing awesome guys.. The guys here did it in 10 days as well so it can be done. NIce work have fun.. Now Neil can can load a B rip once again..
  11. Ryan
    Ryan
    ADMINISTRATOR
    Whoever ran those fuel lines has got some talent with the bender for sure!
  12. ric
    ric
    This is awsome Dave, nice job. I am embaressed to tell you how long I have been "working" on my '32 and how little I have gotten done. ****.
    Hey if you are in a jam I have a 350 sbc slated for the '32, it's sittin on the floor and it is a long way from going in, you are welcome to borrow it. Also have a brand new Walker radiator for the project, fits a '32 grill shell, you are welcome to borrow that as well.
    I wanna see that car in Paso.
    We are leaving Marin fri am if you guys want to caravan.
  13. heyitsnate
    heyitsnate
    holy chit dave!!! is that one of the infamous swanx bus seats? i love those things. man that thing is awesome!
  14. Wow, this is too cool! i was checking out craigslist and saw 2 '56 265's on there. one was just an engine for $150, the other was an engine with powerglide for $300.
    James
  15. beatnik
    beatnik
    Too cool redbeard, posts like this, are why the HAMB rules.
  16. rjb
    rjb
    from ICT KS
    'nuff said
    rjb
  17. redbeard
    redbeard
    Hey guys checking this at work.
    I have to admit you guys are keeping my spirits up.
    we were pretty bummed to have the crack still leaking.
    I have to give credit where it is due, Jeff came up with the idea for the horn bell on the steering column.
    I ran the fuel lines, so thanks ryan,
    I personally have learned alot from the hamb and have seen some really great ideas and projects. I am happy that you guys find our build of interest.
    the fact there are people on here who are willing to help
    means alot to me and I have tried to do the same for the
    folks I have met on here.
    Good news is we have another radiator, from a 64 chevy truck with a six. it fits well and should be more than enough to cool the motor. bad news is the sides are br*** so we can't weld on the grill mount brackets like we would have. So I think we will rivet it on and come back and solder it. I have never done the soldering on a radiator and have not been able to find any good info on how to do it.
    so we may have to farm it out to the radiator shop. It will
    probably be best, but I want to learn to do it.
    thanks again guys
  18. redbeard
    redbeard
    so here we are tuning up the running motor
    NO more Leaks, yippie.
    we rebuilt both carbs, one had blasting media in it. Unbelievable, Neil bought them as rebuilt.
    everything was ready to go, Neil was a little scared so went over the car one last time. then I told him he better get in and drive it before I do.
  19. redbeard
    redbeard
    Here he goes first drive
    He got about 15 feet down the road and then got into it, fun stuff man.
    here is what happens when you don't know how to use a camera, kind of cool though.
    this made all the struggle worth it, is this guy having fun or what
  20. OldSchoolObee
    OldSchoolObee
    GOOD JOB GUYS!!!!!!!! that last shot makes it all worthwhile,huh?:D
  21. Completely and totally awesome! Great Job... I love it....
  22. chopper daddy
    chopper daddy
    Monster Garage my A@@! That rocks! Wish I had the time and the means. It's great to see the progression! Just in time for summer cruizin.
  23. Killer
    Killer
    ****in rad man.
    Where'd you get that carb adapter?
  24. HeX
    HeX
    Man that ****IN RULES!!!!!!!!!!
    What are the sizes of the rims and tires?
    They look perfect!!!!!!!!
    That is good ****!
    Tim
  25. redbeard
    redbeard
    thanks again for the comments guys
    here some more pics after we drove it around.
    the buzz still has not worn off.
    the rims are 16" and the fronts are 450 firestones and 700 rears.
  26. WOW!! Now that's what ya' call a thrash.
    Picked a nice number to put on the door.:cool:
    I like the way you located the rear end. Better than split fixed end radius rods. This deal should be bind free. Applying a bunch of torque to the radius rods would be my only concern, but you'll probably smoke the tires before ya' can hurt anything. I'd like a follow-up report on how it works for ya'.
    This build is inspirational. Nice job.
    Except for the lights, this reminds me of a quick build of an oval track race car that you'd see a good crew do 35 years ago!;)
  27. Bondoboy
    Bondoboy
    I love it! Its a *****in little driver. I would drive the wheels off it. I love your A bone too, damn I love that thing. I have its picture as my desktop, the black and white one with just the color body. Lucky *******s!
  28. huffreport
    huffreport
  29. monaroau
    monaroau
    HOLY ****
    That is great work guys. I wish i could do the same:rolleyes: :rolleyes:
