Technical Can you double flare aluminum tubing?
Discussion in 'The Hokey Ass Message Board' started by Jokester, Oct 9, 2024.
  1. Jokester
    Jokester
    Can you double flare aluminum tubing? 3/8" fuel line. I've done steel tubing before, but didn't know if it works on aluminum too.
    thx,
    .bjb
    Sharpone likes this.
  2. RodStRace
    RodStRace
    I copied your ***le and did a search.
    https://www.holley.com/blog/post/ho...eal.?msockid=1e437518688968461491600b69f0694a
    Should answer your question and cover the unasked ones too.
    When talking about the bits that go into building rods and customs, especially if you are trying to emulate a HAMB era, look at industry from the era. Aircraft, stock autos, mil surplus, pro racing. Add a bit more safety, because we have over a half century of lessons learned and better tools and materials. Building to exactly the level they did is going to be sketchy in some things.
    RMcCulley, Sharpone and Unkl Ian like this.
  3. Unkl Ian
    Unkl Ian
    Anything wrong with Stainless ?
    Deuces, 427 sleeper and Sharpone like this.
  4. RodStRace
    RodStRace
    Double flaring to my automotive mind is for brakes. He asked about aluminum and fuel.
    Stainless has it's own issues with double flaring, which is why the line and fittings are different.
    I hope that OP is using the appropriate material, line, and fittings for the task. This has all been sorted over the years to best use and industries have been built to supply the proper stuff for each job depending on the environment, the fluids and the pressures.
    There is always the question of WHY is this done this way, which could be the start of a dive into the knowledge base or could be driven by wanting to use something that's not appropriate for the task due to availability or cost.
    It's one thing to ask if spray paint will work with pro chemicals, it's different to try to plumb a fuel system. Hoping OP is trying to gain knowledge!
    Unkl Ian and Sharpone like this.
  5. Beanscoot
    Beanscoot
    I've double flared copper 3/8" tubing. I annealed it after the first operation.
    This was non-automotive, propane, and maybe not acceptable practice, but it worked just fine.
    I don't know if you can easily anneal aluminum, but I don't think so.
    But then again, there's probably many different kinds of aluminum tubing, some more malleable than others.
    Unkl Ian likes this.
  6. nochop
    nochop
    from norcal
    I used 3/8 steel brake line with single flare jic fittings. Wasn’t to bad price wise, but it achieved the look I was after IMG_5608.jpeg IMG_5610.jpeg
    Deuces, LWEL9226, jazz1 and 4 others like this.
  7. K13
    K13
    Metal shapers anneal aluminum all the time. Either cover the panel with acetylene soot or sharpie marker ink and burn it off. Panel annealed.
    alanp561 and CSPIDY like this.
  8. warbird1
    warbird1
    But that depends upon the alloy and heat treatment of the aluminum being worked on...
    RMR&C likes this.
  9. Harv
    Harv
    from Sydney
    Fogger likes this.
  10. blue 49
    blue 49
    from Iowa
    I've double flared aluminum fuel line tubing with no issues.
    Gary
  11. deathrowdave
    deathrowdave
    from NKy
    No need to double flare fuel line . Single flare is probably good for 150psi . I worked in the liquid propane business for 36 years , single flare is approved method of sealing
    Deuces, loudbang and nochop like this.
  12. Unkl Ian
    Unkl Ian
    Actually, not that hard.
    But will Aluminum fuel line live on the street ?
    (application not specified by OP)
