Can you get rear end ratio from VIN?
Discussion in 'The Hokey Ass Message Board' started by Coach529, Feb 10, 2013.
  1. Coach529
    Coach529
    Found a Gen 2 F Body parts car to steal a rear end from. The snow was too deep and I was too lazy to crawl underneath it yesterday to see if it had a tag.
    Is it possible to pull the rear end ratio off the VIN?
    Thanks Fellas!!
  2. BOHICA
    BOHICA
    Something that old, I wouldn't trust it even if I could get the ratio from the VIN.
  3. Coach529
    Coach529
  4. 65ssnova
    65ssnova
    from Tulsa OK
    No you cant, but if you trust that its still stock check the gearing for that car during that model year, and it will give you an idea.
  5. Groovybaby6
    Groovybaby6
    from Denver
    Isn't it on the data plate on the door? Fords have them listed there, not sure about GM.
    My '64 Falcon has the axle gears listed there.
  6. DD COOPMAN
    DD COOPMAN
    Look under the rear seat. May find the "build sheet" with the rear-end ratio on it. DD
  7. Should have a code stamped on the axle tube. Not as convenient as the vin but its there. Or, as stated research what ratio the exact combo the car has and that'll get you about 95% there. Remember to check for ac as a lot of cars had a steeper ratio with air than w/o.
  8. BOHICA
    BOHICA
    '86 is a third generation F body. You said second generation. ;)
    One that recent, there's a fair chance you can write down the VIN and call a dealership. Or, if you find the RPO sticker, look for the "G" codes. GT4, GT5, GU6, etc. G80 means it has/had posi-trac.
  9. Coach529
    Coach529
    Right you are.....
  10. Coach529
    Coach529
    Vin is:
    1G2FS87HGL242983
  11. BOHICA
    BOHICA
    You're missing 1 digit from the VIN.
  12. Coach529
    Coach529
    Corrected VIN:
    1G2FS87H8GL242983
  13. patrick66
    patrick66
    No rear axle codes in a VIN.
  14. shinysideup
    shinysideup
    from ruskin, fl
  15. big duece
    big duece
    from kansas
    If its camaro or firebird, its probably a 3:42, or 3:23 gear.
    the code is located on the right side front of axle tube close to diff
    axle code axle ratio axle type
    2je 2.73 std
    2jg 3.08 std
    2jh 3.23 std
    2jj 3.42 std
    2jr 3.42 posi
    2jw 2.73 posi
    2jx 2.93 posi
    2jy 3.08 posi
    2jz 3.23 posi
    2ke 2.73 std
    2kf 2.93 std
    2kg 3.08 std
    2kh 3.23 std
    2kh 3.42 std
    2pe 2.73 std
    2pw 2.73 posi
    2px 2.93 posi
    2py 3.08 posi
    2pz 3.23 posi
  16. NEWFISHER
    NEWFISHER
    from Oregon
    Coach,
    I just logged onto Dealer Globac Connect and the vin is no longer supported by GM. Grab the "G" codes on the glove box sticker and we can help.
  17. k9racer
    k9racer
    a easy way to check. A lot easier to do with 2 people.If non posi ie open spider gears. Mark the drive shaft position. then mark the wheel position. rotate the wheel 2 turns and count the number of revolutions of the drive shaft,, 2 and 3/4 equal to 2.75 2 and a half 2.50 if it goes a little past just do a good guess like 2 and around 7 oclock pos is a 2.56 so I hope you get the idea of what I mean.. Now on posi you only need to turn the wheel 1 time.. I hope this helps.. Bobby..
  18. Coach529
    Coach529
    Thanks for the help guys!!
