Technical Can you help me identify this HALIBRAND QUICK CHANGE
Discussion in 'The Hokey Ass Message Board' started by justachevyguy, Jul 16, 2022.
  1. justachevyguy
    justachevyguy
    from Miami, Ok.
    Hello fellow H.A.M.B'ers...
    Can you help me identify this HALIBRAND QUICK CHANGE REAREND.
    It see a "solectria"and it says halibrand on the side casing but no other marks. It is 51" over all length and from bolt hole to bolt hole it's 39". IMG_5316.jpg IMG_5317.jpg IMG_5318.jpg IMG_5319.jpg 679707516.jpg 679707524.jpg 679707533.jpg 679707540.jpg 679707600.jpg IMG_5316.jpg IMG_5317.jpg IMG_5318.jpg IMG_5319.jpg 679707516.jpg 679707524.jpg 679707533.jpg 679707540.jpg 679707600.jpg
    Also it has no axles, where do you buy parts for this?
    Any help would be greatly appreciated.
    Deuces and tractorguy like this.
  2. Tim
    Tim
    from KCMO
    Also has no place for change gears if that was a quick change it doesn’t look like it is anymore? Maybe there’s a separate back piece that houses them that’s missing?
    Deuces and Desoto291Hemi like this.
  3. studebakerjoe
    studebakerjoe
    Solectria manufactured/ converted cars to electric. Not sure if they're still in business.
    tractorguy likes this.
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The side bells appear to be off the shelf Halibrand V8 parts. The center section is likely a proprietary casting, probably derived from a cut down Halibrand part. Halibrand had non QC centers where the pinion is on the same centerline as the axles.
    Why the bolt on cover? Take it off, and see what's in there.
    My guess is that the differential is 90s Halibrand.
    Take the side covers off and see what you've got. Don't be skeerd! There is nothing in there that will hurt you and you can't mess anything up. You won't change the preload or backlash. Just unbolt a side plate and use the two tapped holes (5/16-18) with some bolts to jack the plate away from the center.
    You only need to do one side but which one is the question. Looking at the Solectria on Wikipedia it may have been driven from the rear. No problem, if you take one side off and you can't lift the differential ***embly out, just do the other side.
    I probably have any parts you may need. Axles are really only dependent on splines and what brakes you may have.
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
  6. alchemy
    alchemy
    Was never an actual quickchange. The pinion is coming in the center, and would have to be a low shaft to reach all the way to the back.
    Tim and Desoto291Hemi like this.
  7. justachevyguy
    justachevyguy
    from Miami, Ok.
  8. justachevyguy
    justachevyguy
    from Miami, Ok.
    GearheadsQCE
    Can you please PM me.
  9. Thats cool looking at least!
  10. seb fontana
    seb fontana
    from ct
    There was a guy that sold at West Springfield, MA January swap meet that had a non-QC alum center, looked to be Champ size, I could tell the pinion was on center but never saw the back. I wanted to ask the application but the guy was always busy..
  11. DDDenny
