Can you re-hone a block if some minor rust has set in?
Discussion in 'The Hokey Ass Message Board' started by swimeasy, Oct 29, 2010.
  1. swimeasy
    swimeasy
    It's not to bad, but a spot or two may be a couple of thosands deep. Can ya save one like this? Please don't tell me what a dumb ass I am as I feel pretty bad about letting this happen in the first place!
  2. pincher
    pincher
    from Saginaw
    I just bought a 350 4 bolt for $50.00 this summer 2 of the cylinder's were badly pitted and rusted bad. Took the block down to the machine shop, no problem, boared the cylinder's out 30 No problem's ran my coupe the rest of the summer........PINCHER
  3. Deuces
    Deuces
    I'd have to see a close-up pic of the infected area...
  4. swimeasy
    swimeasy
    This block was boared .60 over (flathead). I have already bought pistons and rings. I will put some pictures up and see what you guys think.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If you can't see any pitting once you've honed out the bores, it's no problem.
  6. I'd say that all you'd need is a bunch of lube and some light hone work to set it straight. Real minor stuff, I'd scuff out with diesel fuel and crocus cloth.
    Bob
  7. lostdutchman
    lostdutchman
    I'm assuming you are talking about doing it yourself
    if its just fingerprints and atmospheric rust on a freshly machined block
    no problem just don't over do it and get the cylinder out of round
  8. Flatheadguy
    Flatheadguy
    Uh, we all know that there is a difference between "boring" and "honing", right?
    Posts #5...#6...#7, have it exactly right.
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    What do you have to lose ,If you hone it and try it ,I dont think you will break a ring ,May oil the piston walls a little more .Not politically correct ,But I had a chevy inlie 6 in my boat and water got into a cylinder and Motor was stuck ,Pulled head and found rust ,Wetsanded with crocus cloth and oil .Had pits in wall ,Buttoned it up and ran it ,Worked fine,,,,,,
  10. whid
    whid
    I had a 350 4 bolt bored .30 over had the crank done then got divorced and the project stalled for nine years....it held up surprising well but did develope a few rust spots...i was lucky, it wasnt that bad they were able to hone it out and no pitting....you got nothing to lose ...good luck..........whid
  11. Chevy55
    Chevy55
    from Nebraska
    Had a machinist tell me once that he didnt worry that much about pits. He said they just hold oil. He said when you have scores the oil travels in the scores and gets burned in the combustion chamber.
  12. LB+1
    LB+1
    from 71291
    : Can you re-hone a block if some minor rust has set in?
    <HR style="COLOR: #e5e5e5; BACKGROUND-COLOR: #e5e5e5" SIZE=1><!-- / icon and title --><!-- message -->Had a machinist tell me once that he didn't worry that much about pits. He said they just hold oil. He said when you have scores the oil travels in the scores and gets burned in the combustion chamber.
    True True it is - And If you have chrome ring's that want seat - Take the
    plugs out put a little Comet, Ajax etc in each one spin it over a few times and they will seat.
  13. nocoastsaint
    nocoastsaint
    Unless it really tore the cylinder walls up just clean it up or hone it and go.
