Technical Can you "un-do" J-B Weld?
Discussion in 'The Hokey Ass Message Board' started by tubman, Apr 19, 2015.
  1. tubman
    tubman
    I J-B welded a reamer into a socket to ream the throttle shafts on a WCFB I am rebuilding. (It seemed to be the best way to go at the time.) It worked out pretty well and I am re-***embling the carb, but the tool I made is not in exact alignment. It would have been perfect if I had it accurately aligned, so I'd like to take it apart and put it back together a little more carefully. Anybody know the best way to get it apart? (If there is any.)
  2. Model T1
    Model T1
    Did you use too much? That would have been better but it's good that it sorta worked.
    If I suggest a big hammer will you think I'm a smart ***?
  3. tb33anda3rd
    tb33anda3rd
    can you weld another socket to that socket.....but straight?
  4. blowby
    blowby
    from Nicasio Ca
    If you can't knock it back out from the other side with a punch I'd burn it. Put the reamer in water if you're afraid of temper loss.
  5. LM14
    LM14
    from Iowa
    Heat above 600*F. That or grind it out.
    Google is your friend.
    SPark
  6. Bugguts
    Bugguts
    Yep,....heat
  7. Unkl Ian
    Unkl Ian
    Soak in lacquer thinner.
  8. pdq67
    pdq67
    Try soaking it in Methylene Chloride if you can find any??
    It is about the strongest solvent there is, imho..
    pdq67
  9. If J-B is a 2 part epoxy, it will soften up in the oven at anything over 100Celcius.
    It might stink the place out though, so maybe a heat gun would work.
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
  11. nrgwizard
    nrgwizard
    from Minn. uSA
    IIRC, JBWeld doesn't stand up to anti-freeze very well. I don't know how long it would take, but I'd try soaking it in anti-freeze for a couple of days, or a week. Would only loose some time iffen it didn't work.
    Marcus...
  12. sdsmith33
    sdsmith33
    from kansas
    It doesn't like gas either so you can soak it in gas it might take a day or two to get soft
  13. Lots of heat but don't use your Honey's kitchen oven. Go outside and use your barbeque grill.
    Ask me. I'll tell you why.
  14. striper
    striper
    Really? I've done fuel tank repairs that have lasted years.
    I'd knock it out with a pin punch from the other side then drill the remaining JB out (enough so you can reset the reamer)
  15. woodiewagon46
    woodiewagon46
    from New York
    Heat will do it. Small propane tank is enough. It will catch fire and give off a lot of black smoke but you will be able to extract the reamer. As far as the anti freeze theory, I repaired a cracked plastic radiator top tank with J-B Weld on one of my modern cars about 6 years ago and it is still going strong.
  16. I will if no one else will but from me that is a compliment. ;) :D :D
    Tubman,
    What I would do is put the socket in a vice and take a hammer and punch and drive the reamer back out of the socket, I think that a couple of hard raps should break the ****** loose. You may not save the socket or maybe you can get in with a dremmel and clean it out enough to use it again. That is the biggest loss you should experience though is the loss of the socket. I probably have a duplicate if you don't and it couldn't cost much for me to mail you one. ;)
    Model T1 likes this.
  17. stimpy
    stimpy
    heat is the only way once its cured if the stuff was mixed without enough part b it will stay soft , used a propane torch on the socket and wrap a wet rag around the reamer ( even though it its only going to cut soft metal on the carb base ) it keep its temper . just try to get the socket loose and then mechanically remove it from the reamers shaft , on making plugs /tooling like this we spray the inside of the holder ( socket ) with silicone or a layer of light oil so it will not bond to the part but makes a perfect mould
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, ww46;
    You're probably right. In some past life, playing around w/hho & Joe Cell stuff, I was going to use JBWeld as a seal, instead of Sikaflex. Called JB & they told me no decent (med->long term) exposure to antifreeze. So I never tried it that way. I realize it's a two-part epoxy w/metal dust filler. WTF do I know??? :) . Glad it's worked out for you.
    Marcus...
  19. LOL We used some on the head face for a pair of 440 heads back in the mid '90s, the face was pitted we took a ball mill to the deeper pits to get us some clean metal, cleaned the hell out of it then smeared the JB weld and let it set up for 24 hours. faced the heads and they are still running to this day in an OT Charger. granted they should have no Antifreeze exposure as long as the car doesn't blow a head gasket and it is held firmly in place. It was a stop gap measure to get the car on the road and as always anything temporary is permanent. :)
  20. tubman
    tubman
    Heat sounds like it might be the answer. If the J-B Weld will just start to soften, I only need it to move it just a little to get it straight. Will it harden again once the heat is removed? If so, that'll be perfect. I have a heat gun (and a torch in reserve). I'll let you know what happens.
    I got the reamer from "Carb Junkys" along with the bushings. They tell you to chuck the piloted reamer (the end with the flutes) into a 1/2" drill. I didn't think this was a good idea, so I found that a 10mm socket would fit over the reamer fluted end and not spin, though it did wobble a bit. If I had to do it again, I would use "Liquid Rubber" or something flexible instead of J-B Weld. (It probably would have worked fine without anything extra, now that I think about it.) If I can heat it up and move it and it hardens back up, I'll be OK.
    As an addendum, the bushings worked great, although they need to be reamed on the inside after installation to get a perfect fit. I would recommend them.
  21. Russco
    Russco
    from Central IL
    Heat is probably the answer but it's got to get pretty hot. I'm sure it will ruin it once you get it hot enough to move it. I've used it for years to reshape intake ports in off topic motors without many problems at all, running on both gasoline and Methanol.
